pedel sticking - Ford Powerstroke Diesel Forum
Old 01-05-2008, 08:22 PM
Send a message via AIM to 7.3ford350
pedel sticking
just wondering if anyone has had a problem with the throttel sticking when you are driving and if so what it was that caused this problem.
thanks
Old 01-06-2008, 02:51 AM
thanks
most likely the switch on the go peddle is sticking..these are fly by wire throttle...go to napa or the like..get some electrical spray cleaner..take the switch off of the go peddle..spray it good..use a tooth brush to get heavy dirt off..make sure it is dry..(it is fast drying) put it back together and you should all set..
Old 01-06-2008, 05:05 PM
thanks........i will look into to that tomorrow. anyone else have any ideas?
