window issues - Ford Powerstroke Diesel Forum
Old 01-04-2008, 11:27 PM
window issues
Ok, here's the problem, passenger window goes down half way then slows to a crawl. if it rains the window works fine. i am gonna be pullin the door panel and replaceing speakers tomorrow. is there a way to just grease the da*n thing or is this something serious with the motor???
Old 01-05-2008, 12:08 AM
Powerstroke Techie
Mine was doing that, soaked her with wd-40 and now she works good, just be careful about getting it on the glass and seals or it will smear the window every time you go up and down. Greasing the slides may be better but it was a pain to get to on mine even with the door panel off.
Old 01-17-2010, 03:30 PM
my early 99, same thing! how did you fix?
Old 01-18-2010, 09:35 PM
Same Problem
I have a '00 nodel with the same problem... I actually pulled the door panel and replaced the window motor, greased the regulator and still no change. I did notice that the window motor got extremely hot when I tried to roll the window back up, to the point of kicking the thermal overload in the motor. At this point I am not sure if there is a problem with the regulator and window tracks or if it's a wiring problem... Please help!!!! I can't stand to ride around with un-tinted windows much longer!!! LOL!
How would I go about checking the readings on the wiring? How many other people are having this problem?
Old 01-18-2010, 10:17 PM
I have a 99 and had the same problem with the front passenger door. Just did the WD-40 trick today to the tracks the window slides in sinsce I had it apart to do the aluminum foil fix to the door lock actuator. Both are working fine now. Don't know how long it will last. WD-40 tends to dry out quickly.
