No Backup Lights
Ok, its dark and I kick Martha in Reverse, but no backup lights. . . fuse is good and bulbs are good. Any ideas??
I just had the same problem with my 99 SD at work. The 2 things I found was the fuse was actually loose in the box, tighten that bit still no lights. We had a busted trailer plug (the large 7 pin). Unplug the wiring harness for the trailer plug and our reverse lights worked.
If not that, I would start looking at the shifter switch or relay. |
thanks eric ill check out the trailer plug and let you know.
no backup lights
Just were are those located.I don't see any holes or nothing in the bumper.
NP, keep us informed!
problem solved, i had an extension for my 4 pin trailer plug. unplugged it and worked fine. thanks for pointing me in the right direction.
