need instructions chip install - Ford Powerstroke Diesel Forum
Old 01-04-2008, 11:03 AM
where is a sticky on chip install
Old 01-04-2008, 11:04 AM
here you go bud.... let me know if you have any questions: Diesel Movies - I install a DPTuner F5 chip in my buddies truck. Positions were Stock hi idle 60tow 80econo 120 race 140smoke.
Old 01-04-2008, 12:45 PM
Smile good job on the video
very nice. great job that helps us newbies a lot.
Old 01-04-2008, 02:17 PM
well I got my TW chip in and having some problems. It is a 6 pos:
1. Stock
2. Economy
3. Daily
4. Tow
5. Extreme
6. Smoke
I can start the truck in any Position but if I switch on the fly from pos 2 to pos1 the engine dies. Also if I switch from pos 5 to 6 it dies. I called Tony and he told me to 1. See if the terminals on the computer where clean and 2. Make sure the chip wasnt in there crooked. Niether of those seem to be an issue.
Please help
Old 01-04-2008, 02:20 PM
if those terminals arent cleaned perfectly... it will cause all kinds of issues for the chip and your truck. make sure they are absolutely clean as can be and if the truck still does it, maybe its a chip/tuning issue. good luck man.
Old 01-04-2008, 02:24 PM
well I when i took it off to inspect it I used some emry cloth on it again just to make sure the silicon was off but I cant rub it any more cuz the copper is starting to show on the edges of the terminals
Old 01-04-2008, 03:44 PM
mine had those issues when i didnt clean the terminals good enough... but after i cleaned it again it has worked flawlessly
Old 01-04-2008, 03:57 PM
Raul,
Did you scuff of the silver and expose te copper ? If so/not how much?
I'm like a kid at X-mas with a toy and no batteries
Old 01-04-2008, 04:00 PM
Originally Posted by a1l71700 View Post
Raul,
def not down to the copper... but you can see the silver change color a lil but not enough to see the copper.... make sure its on their tight and that all the contacts are hitting the right location. if all else fails you can send it back and im 100% sure Tony is gonna make it right..... he wont stop until your satisfied
-Raul
Old 01-04-2008, 04:03 PM
Im at the point where you can just start to see the copper color showing through the edges. The silver is still on there and im afraid do scuff anymore...is there a contact cleaner that could be used?
