Lower EGT's - Ford Powerstroke Diesel Forum
post #1 of 7 Old 01-03-2008, 06:44 PM Thread Starter
DS650's Avatar
Lower EGT's
OK, so what is the best and most cost effective way to substantially lower my EGT's? 100-200 degrees would be great. I don't really want to dump $1300 into a banks tecni-cooler. Any suggestions would be appreciated.
2001 F350 4x4, 7.3L, Edge Juice with Attitude, 4" turbo back, AFE stage 2.
Thanks,
Scott
DS650 is offline
post #2 of 7 Old 01-03-2008, 06:51 PM
Desert Shield/Storm Vet
vitalidle's Avatar
You could put a water/meth kit on will lower egt's and boost hp at the same time.
2002 F-250 4x4 EC, SRW, SB
Auto 93,000 miles
DP Tuner F5
ATS Compressor and 1.0 Exhaust housing high flow back plate
Turbo Back 4" Silverline Exhaust Mbrp Muffler Delete
Isspro Trans,Pyro,Boost Triple Pod
Fumoto Oil Drain Valve
AIH Delete With Boost Fitting
vitalidle is offline
post #3 of 7 Old 01-03-2008, 06:52 PM
vitalidle's Avatar
Snow Performance: Home
Auto 93,000 miles
DP Tuner F5
post #4 of 7 Old 01-04-2008, 06:48 AM
CSIPSD's Avatar
NO NO NO NO NO.... Dont go with Snows... They suck bigtime, There being sued for stealing others engineering work...
Water Injection, Methanol Injection systems | Coolingmist Better kits, better parts, better controlers...
Also Diesel was having a sale on Sperco IC for 1100 shipped... Intercooler is a better bet in the long run, but water injection is a short term fix.
01 F-250 SC PSD,320k,16 Isspro Gauges, AFE-2,CCV Mod,IAH delete,map reg,Modded H2e, 6.0 IC, 230/100 from P.I.S, Studs, 910 springs, Forged rods, Water injection,Hydra chip-No Limit/Gearhead tuning, Swamps HVHF IDM, MBRP 4" dual's, Aero, 6" tip's, 4" Revtek lift, 37/12.5/16.5 MT's
Joe
DYNOPROVEN.COM, PERFORMANCEINJECTIONSYSTEMS.COM and RIFFRAFFDIESEL.COM
CSIPSD is offline
post #5 of 7 Old 01-04-2008, 07:42 AM
vitalidle's Avatar
Yeah I was just using them as an example. I surely don't have any experience with them, but CSIPSD has you pointed in the right direction
Auto 93,000 miles
DP Tuner F5
post #6 of 7 Old 01-04-2008, 07:55 AM
CSIPSD's Avatar
Meant no dis... Just the Man and the Company are dirty...
Joe
CSIPSD is offline
post #7 of 7 Old 01-04-2008, 08:01 AM
vitalidle's Avatar
Not a problem at all glad he is getting good info to make a decision
Auto 93,000 miles
DP Tuner F5
