03 6.0 turbo fit a 02 7.3 - Ford Powerstroke Diesel Forum
Old 02-28-2013, 08:39 PM
I am wondering if the 2003 6.0 turbo will fit on my 2002 7.3??
Any help is appreciated.
Old 02-28-2013, 08:48 PM
I am almost certain that the 6.0l turbos will not work in the 7.3's The 6.0's have veined turbos and the design will not work.
I'll let the more experienced answer with the proper info
Old 02-28-2013, 09:13 PM
It's been done. Is it worth it? No. Even if you put the time and money into making it work right, the 6.0 turbo is still almost too small for stock injectors.
If you just want a louder whistle get a WW. If you want an actual upgrade, look into the WW G2 or a 38R.
Old 03-01-2013, 03:22 AM
The 6.0 turbo is a variable geometry turbo. It will not work on a 7.3. The PCM has no idea what it is or what to do with it. If you did bolt it up the truck would have no power and smoke like a freight train.
Here check this out. May clear things up for ya.
Variable-geometry turbocharger - Wikipedia, the free encyclopedia
Old 03-01-2013, 10:57 PM
Re: 03 6.0 turbo fit a 02 7.3
Thank you to everyone for the info!! Im a new owner and love the whistle of the 03.
Def gave me some insight!!
Old 03-01-2013, 11:08 PM
Illiana Chapter Director
Not trying to derail here, but 6.0 injectors are bigger than 7.3 injectors as far as fuel flow and the 6.0 charger cleans ours up fine. A 6.0 turbo would be more than enough air for 7.3 injectors. Would be a pain to get the turbo to work though. Just my .
Old 03-02-2013, 02:17 AM
I would second the ww2.
Sent from AutoGuide.com App
Old 03-02-2013, 05:59 AM
Yes it'll work. All you need is some duck tape, wood screws, and a flux capacitor.
Old 03-02-2013, 04:58 PM
^^^^^^2nd that, as long as you replace the muffler bearings at the time of install
Oh btw
