Body Lift - Ford Powerstroke Diesel Forum
Old 01-03-2008, 12:41 AM
Body Lift
I know that know one makes a prodution body lift for the powerstroke but I have seen several custom rides with a body lift. I would lov a 3" for my truck not so much for the lift but to ease in working around the back of the engine and on top of the trans. Think of how easy it would be to put a large downpipe in with all that space. Both Cummins and D-max trucks have body lift kits you can buy. So dose anyone know who to call.
Old 01-03-2008, 12:44 AM
it shouldnt be motor specific. just truck specific. make your self some with a half inch drill bit and hockey pucks.
Old 01-03-2008, 12:47 AM
That has got to be the most redneck thing I have ever heard. Funny as hell though. LMAO
Old 01-03-2008, 01:58 AM
really you think about it when they lift the cab to work on the truck it is six bolts sso you could get your bolts out lit the truck on jacks(slowly) and see if your wiring could stretch the three inches,might have to go 2" or inch and a half. I think ive seen bodylifts for superduty gassers but not the diesels must be something?
Old 01-03-2008, 02:22 AM
In my opinion body lifts look like crap. The frame hanging out from under the truck is ugly. Also it will decrease the value of your truck. I wouldn't put a body lift on anything.
Old 01-03-2008, 04:24 AM
Well, there's lots of factors in with a body lift. Does the steering shaft on these trucks have room to slip out for the body lift? Is the fan shroud a two piece so you can take the bottom piece off? Little things likie that can be a pain in the butt. Yes you can always cut and reweld the steering shaft, cut and rig up the fan shroud. In that case all you need is body blocks and bolts. If they don't make a specific kit then count your rig and see how many body mounts it has and find a kit that has that many blocks. Then when you get your stock body bolts out go to your local nut and bolt store and buy all the bolts 3" longer. Where there's a will there's a way. As a matter of fact I might have an extra body lift lying around. They sent me the wrong one for my Blazer, then they sent me the right one but never sent the prepaid postage for me to send the wrong one back. I'm gonna hang on to it for a little while but if I still have it a couples months down the road it's gonna find it's way GONE!
Old 01-03-2008, 04:33 AM
thats supposedly because of weight issues, which to me wouldnt make a difference because the motor rests on the chasis not the body mounting system. i just hate the fact that on our trucks the damn bolts go through the inside of the cab. royal pita. on my tahoe i did a body lift in 45 minutes. on my friends single cab f150...3 1/2 hours
Old 01-03-2008, 08:36 AM
International Threat
Body lift problems...
Motor stays in the frame - the intercooler goes up with the body...
Old 01-03-2008, 09:46 AM
FWIW as I know it ,the reason body lifts aren't made for OBS PSDs is the intake,mounted to body and engine. Get an after market intake and the body of a F250 gasser should be the same as a PSD,,yes?
Old 01-03-2008, 10:21 AM
I was in a local repair shop and saw an 2003 F 250 with the 7.3, it had a 3" body lift, could not see anything off the wall or special having been done to the truck. it looked like the fan still lined up good with the Rad and the intercooler all the wiring was ok. And it does give you plenty of room around the back of the motor.
The only thing was the intake tube to the turbo needs to stretch or be longer, because the airbox moves up and the motor doesn't.
