Auto 4x4 problems - Ford Powerstroke Diesel Forum
post #1 of 16 Old 01-02-2008, 09:47 PM Thread Starter
Auto 4x4 problems
99 F-250 w/ auto hubs... I know that I should probably just change to manual, but I would like the auto to work. Before the weather got cold, the auto would work. Since its gotten cold up north sometimes it works and sometime not. More time not! From what I understand two possible problems. #1 seal on driveshaft? or #2 hubs? How do I figure out where the issue is? Is there a simple way to check? Oh, If I manually lock hubs, the 4x4 works fine.
walleye guy is offline
post #2 of 16 Old 01-02-2008, 09:50 PM
Raul@Stealth Automotive's Avatar
if your driveshaft is spinning then your TC is engaging and its your hubs.... not sure how cold its getting their but water can seep into the hubs and when it freezes it expands and screws them up.... i finally said forget it and switched to Warn Premium hubs....
Raul@Stealth Automotive is offline
post #3 of 16 Old 01-02-2008, 09:52 PM
duct tape & zip ties
bigcountrysg's Avatar
Most likely it is a vaccuum leak. There is a seal inside the wheelbearing assembly. If that goes bad you loose vaccuum. Which in return does not allow the hub to lock automatically. I would do a vaccuum test on each hub. To see if it is holding a vaccuum. When I replaced my wheelbearings I found out that the passengerside seal was bad. Which is why my hubs would not lock automatically. Now I just lock them in manually.
Your Actions Today, Decide Your Future Tomorrow
2005 6.0 Crew Cab Long Box Lariat, current truck
2004 6.0 destroyed by contaminated fuel
2002 7.3L burnt
bigcountrysg is offline
post #4 of 16 Old 01-02-2008, 09:57 PM Thread Starter
so how do i know if driveshaft is spinning? if i turn switch to 4x4 you are saying that the shaft should be spinning . not to be stupid, but I'm the least handy guy you'll ever meet. I live in N. MN and its about -10 right now. with the wind, about -20 thanks
post #5 of 16 Old 01-02-2008, 09:59 PM
yes if you switch to 4x4 have someone move your truck forward and it will move..... if your hubs are messed up your 4x4 will not engage and tires wont spin...... i know because this is what happened to me....
post #6 of 16 Old 01-02-2008, 10:02 PM
k..i was born and raised im montana...and ive seen this many times before..
what you have going on is a hub seal leak. There are two main seals for the vacume....the backside hub seal that is pressed on...and the yellow o ring on the hub that seals the hub...
one of the two is leaking on at least one side and thats why the its only happened as the weather got cold...as the seal shrunk...the problem presented itself...
mschn99 is offline
post #7 of 16 Old 01-02-2008, 10:03 PM Thread Starter
Great, I will try that tomorrow. Thanks for the help!
post #8 of 16 Old 01-02-2008, 10:06 PM Thread Starter
Marc, so is there a kit to replace the seals? If so, and I get it fixed, will the new seals last for awhile or will the same thing happen soon after changing.
post #9 of 16 Old 01-02-2008, 10:09 PM
there is no kit....you will need to either pull vacume on both sides to determine which side is leaking....or just replace both sides if you want to be really save and or not test it...
as far as the new seals.....ive seen them last 10k and ive seen them last 250k......both in montana climates. Its not predictable and i really cant say how long they will last...but on average they are about a 100k seal in cold climates from what ive seen...
mschn99 is offline
post #10 of 16 Old 01-02-2008, 10:09 PM
also know that there is a special installer for the backside hub seal that is not cheap......it allows you to press the seal on......you cant install the seal without it...
mschn99 is offline
