Stem in the middle of fuel filter? - Ford Powerstroke Diesel Forum
post #1 of 6 Old 02-28-2013, 03:58 PM Thread Starter
Mr.Ford's Avatar
I was watching a video on youtube where a guy removed the guts from that center stem of the fuel filter. Have any of you guys done this to your fuel bowl? He says is supposed to remove some of the flow restriction.
2002 F-250 7.3L Crew Cab Short Bed
  • Edge Juice w/Attitude
  • Foil Delete
  • K&N <<< Looking to Replace
  • Straight Exhaust Pipe <<< Needs Tail Pipe
Mr.Ford is offline
post #2 of 6 Old 02-28-2013, 04:25 PM
Wannabitawerm's Avatar
Here we go....
Sent from AutoGuide.com App
Wannabitawerm is offline
post #3 of 6 Old 02-28-2013, 05:20 PM
My understanding is that Mr. powerstrokehelp is not the highest regarded "expert" in his field.
SomethinBoutAtruck is offline
post #4 of 6 Old 03-01-2013, 01:19 AM Thread Starter
Mr.Ford's Avatar
Yes that is the guy, seems like a nice fellow. I'm aware this is the internet and everything you read and watch is 100% accurate.
  • Foil Delete
Mr.Ford is offline
post #5 of 6 Old 03-01-2013, 04:50 AM
timmyboy76's Avatar
Alot just "unplug" the connection. Reason being, when that "stem", which is your fuel heater, shorts out, it'll take out the fuse. Problem is, that same fuse, your pcm, fuel pump..etc is all on the same fuse...#30-30amp.
99.5 x-cab 7.3l, 6spd, 161k miles.....
timmyboy76 is offline
post #6 of 6 Old 03-01-2013, 05:05 AM
Colin7.3's Avatar
When i rebuilt my fuel bowl, i removed the heater element completely. But i also found that the stem your talking about was previously gutted.
Colin S. Age:22 Certified Diesel Tech, Infantry US ARMY
E99 7.3 6spd 4x4 6637, 4" straight pipe, 365,000 miles
"wear your high mileage as a badge of honor"
04 GMC 2500 4x4 Duramax/Allison
Colin7.3 is offline
