Looking for pre pump fuel filter for stock set up - Ford Powerstroke Diesel Forum
Old 02-27-2013, 01:43 PM
I have a stock set up - 01 f350 7.3
I won't be doing upgraded injectors or other heavy mods for awhile
So I'm just looking so a good prep pump fuel filter to mount to the chassis under the truck.
One I've seen mentioned before is dahl, I think like a dahl 160
I just want something that pulls water and junk out pre pump
So I'm not looking for a fass or air dog recommendation but others
Thanks
Old 02-27-2013, 01:49 PM
i would think, if you dont do the in-tank mod, then installing a pre-pump, with the oem system, in the tank, it'll be too restrictive for the stock pump.
Old 02-27-2013, 01:51 PM
Go to a large truck dealer (international, cat, cummins, etc) they should have them in the parts dept. i know we do at international.
Old 02-27-2013, 08:34 PM
Re: Looking for pre pump fuel filter for stock set up
Ive got a caterpillar element filter right before the pump on my truck. Saves a lot on replacing the filter above the motor
Sent from my Motorola RAZR MAXX using AutoGuide.Com Free App
Old 02-27-2013, 08:51 PM
I'd have to look at it to see which one it is but its a metal element that you can take out and clean instead of replacing
Old 02-28-2013, 01:08 AM
You could do something like this, with the option of running a second factory pump?
Old 02-28-2013, 07:05 PM
Very interesting. I dig it. You did this? or just found a picture. Because I'm thinking this might be a nice little project but am curious the benefit of adding a second pump or if one is sufficient. Thanks for the picture.
Old 02-28-2013, 07:29 PM
if this is yours - where'd you get the two bases and what are the two filter numbers?
Thanks
an idea i had was a Racor diesel fuel / water separator - whats the GPH rating of our stock pumps?
