Old 01-01-2008, 08:33 AM
tech701 tech701 is offline
Burning Oil ?????
I run synthetic Rotella 5-40 in my 03 f-250 7.3l w/95k. My last oil change interval was 8k at which time Black Stone said I was good to go. In 8k miles I had to add 2 quarts of oil. I'm going to try to do 8k again this time. I'm right at 6k now and I just added my second quart. Does two quarts consumption in 8k said about right.
Old 01-01-2008, 08:39 AM
colo86GN colo86GN is offline
Good question, here's a bump for ya!
Old 01-01-2008, 11:51 AM
Snowman66 Snowman66 is offline
Seafood Hunter
I was courious about that too. last summer i bought a 2000 Excursion. Changed oil to Amsoil, and at 8K had to add 3 qts. Thought that was a little much. have 90,000 mi now.
Old 01-01-2008, 12:00 PM
vitalidle vitalidle is offline
Desert Shield/Storm Vet
Not sure but 2 quarts doesn't sound excessive. I change mine at 5000 and I haven't used any oil up till this last time I fueled up I noticed I was about a quart down. I have about 1500 towing miles on this oil change and its about 200 miles from hitting 5000 so I will go through another oil change and keep and eye on it.
AWD Bare AWD Bare is offline
My 2002 7.3 does it too. Right at 6k miles , in between oil changes , I have to add 2 quarts.
Bump for an answere...
Old 01-01-2008, 12:09 PM
ksttac ksttac is offline
i better go check my oil
Old 01-01-2008, 07:51 PM
ns954 ns954 is offline
In the 7.3L manual Ford does mention that some oil consumption is normal.Two quarts sounds pretty normal to me.Certainly not excessive.
Old 01-01-2008, 08:14 PM
Diesel Freak Diesel Freak is offline
Rice Hunter
WOW Makes me wanna check mine now. I run Semi-Synthetic but change at 5K
Old 01-01-2008, 08:25 PM
Dirk Dirk is offline
Diesel Innovations
The harder I drive mine.. the more oil I will burn. At most, mine will use a quart at 5k. Normally, it's at the low end of full at 5k.
