Old 12-31-2007, 02:54 PM
budracer1 budracer1 is offline
Autometer Tranny Temp Gauge reading 250!!!
Hey guys over the weekend i finally got around to installing all my new autometer z series gauges.Boost and pyrometer seem to be working pretty good reading about 500 to 600 on egt at a cruise and around 3psi boost up to about 25 if i stomp it but transmission kept climbing till it got to 250.Now i know that my transmission isnt that hot or else i would have been walking but is the gauge bad or do i need to do something different.I used the test port for my probe/sensor and did not use a ground as i figured the metal to metal would be ground enough,but maybe i need to run a ground wire?Ive got a evo tuner and with it hooked up it has the tft at 135 to 140 which is probably pretty close i would think,since i was not towing anything and wasnt dogging the truck.Any advice?
Thanks in advance Jason
Old 12-31-2007, 03:00 PM
ipz2222 ipz2222 is offline
It seems someone else had that problem and they added the ground to it and it started working right. I would think screwing into the case would be enough, but some guages won't work that way.
Old 12-31-2007, 03:05 PM
2006PSDSD 2006PSDSD is offline
ΜΟΛΩΝ ΛΑΒΕ
I've got the auto meter phanton gauges. I didn't have that problem, but I did run a separate wire for a ground, from the gauge down to a good ground under the dash. Hope that helps
Old 12-31-2007, 03:14 PM
i daisy chained all the grounds for the lights to a good ground right under the hood where all the wires come through the firewall.If i use one those little blue connectors(lol) and just clip into that ground wouldnt that be good enough?wouldnt be any worse anyway.
Thanks Jason
Old 12-31-2007, 03:20 PM
ΜΟΛΩΝ ΛΑΒΕ
I did the same thing. Maybe you have a bad gauge??? I put my gauges in over a year ago. How many wires are there for the tranny one? One power and ground for the light, and one for the sensor?
Old 12-31-2007, 03:23 PM
yes 1 power and ground for light and 1 power for sensor but now i have not grounded it with a wire yet, i was just asking if i just clipped a ground wire into the ground wire of my light would that be ok.
Old 12-31-2007, 03:52 PM
ΜΟΛΩΝ ΛΑΒΕ
Are you talking about splicing another ground into an existing ground? You can do that no problem. If there isn't a ground, then you don't need to ground it. Just hook the 2 power wires up, and the one ground, and then the sensor (no particular order)
Old 12-31-2007, 04:03 PM
well there is a ground post on the gauge right besdie where the hot sensor wire goes,i will try grounding the sensor and ill get back to you guys thanks!!
Jason
Old 01-01-2008, 09:09 AM
Ok i went out last night and pulled the gauge out and there was a black - and white+ for the lights and then three post for sensor,ignition hot and ground.So i added a ground to the ground post,tied it in to the ground for the lights and it seems to be working now.I took about a 5 mile trip out the road while ago stopping a couple of times and sitting still for a few min,and it never got over 115,which is about what my evo was reading so maybe mission accomplished,since yesterday in less than 5 miles it was up to bout 180.Thanks guys!!!!
Old 01-01-2008, 09:53 AM
ΜΟΛΩΝ ΛΑΒΕ
Glad we were able to help
