Old 12-30-2007, 01:23 PM
Duane Gromis Duane Gromis is offline
Question Fleetgard coolant test
Does anyone know what the test results will be if you run the fleetguard test at a lower temperature. I ran a test at about 45 degrees and the reading I got was a .6 at -30 degrees which tells me that I need to add a pint of additive. I had the coolant changed at a ford dealer and I was afraid that they would mess it up. First I had a issue of not enough coolant and now I have this issue. Should I add the pint or should I run another test with the coolant at a higher temp?
Old 12-31-2007, 05:19 AM
ns954 ns954 is offline
I would retest at a higher temp.I believe they recommend at least 50 degrees? I brought my sample inside and heated it up a little with a hair dryer.As info,it has taken me 3.5 pints of SCA from a complete flush to approach normal SCA limits.
