Question about CCV pressure. Techs chime in please. - Ford Powerstroke Diesel Forum
post #1 of 4 Old 02-25-2013, 08:54 PM Thread Starter
slowcoupe's Avatar
Quoted: 11 Post(s)
So as some of you may have seen I am selling my 2002 7.3. I have this desire to get into a 6.4 but that's a different story. Little backstory on the truck. 2002 7.3 crewcab longbed. has 113K miles on it. Purchased it with 98K. Have done a few things here and there. DP tuner, JW valve body, Riffraff OCR, 5" exhaust, and the CCV mod
So I have prospective buyer A who is interested. But wants to have his home mechanic friend look over my truck first.
First thing I noticed that he did when he first "checked out" my truck was turned it over without letting the GP cycle and then shut off immediately. And then did it again right after.
Second was he took pliers and clamped the CCV reroute hose which I have routed to the back of the truck while opening the oil cap and setting the cap over the fill hole. Which made the cap "wobble" is how I can explain it. He proceeded to tell the guy that he'd pass because CCV pressure was too high. Now I have read and read in the past because my 1st 7.3 a few years ago which was also a 2002 had smoke that exited the ccv tubing or the oil filler neck if the cap was removed while the truck was running (not excessive by any means) and read that it's normal. It is to my understanding that this is Crankcase pressure which is the whole purpose of the CCV to reduce the pressure in the crankcase to prevent seals from being blown. So in my mind of course you plug the ccv tubing the pressure is going to exit from the next easiest opening via oil fill neck with cap removed.....
Is this a real thing? I'm just curious for personal knowledge at this point because I have prospective buyer B who is working on finances as we speak
2000 Regular Cab SHORTY truck.
-7.3/ZF6 combo.
-TS tuned
-5" exhaust to 7" single mitre.
-DJM 3/5 drop
-22" wheels wrapped in 305 nitto 420's
COMING SOON
-Midwest shifter
-DP tuner
-2008 F350 CCLB ZF6 truck. Leveled, 22's w/37s, deleted, H&Stuned etc -SOLD
-2005 F350 CCLB 6" 37's, studded, tuned etc-SOLD
-2002 F350 CCLB 6"lift, 20's w/35's, DP tuner etc -SOLD
-2005 F250 CCLB 8", 20's w/37's bunch of mods -SOLD
-2002 F250 CCSB 4" lift,18's w/35's DP tunes etc -SOLD
slowcoupe is offline
post #2 of 4 Old 02-26-2013, 08:22 AM Thread Starter
slowcoupe's Avatar
Quoted: 11 Post(s)
Morning bump. I posted kinda late last night but hoping this kid comes through with the funds tonight.
-7.3/ZF6 combo.
-TS tuned
-DJM 3/5 drop
COMING SOON
-Midwest shifter
-DP tuner
post #3 of 4 Old 02-26-2013, 01:51 PM
Justin@DP-Tuner's Avatar
Quoted: 47 Post(s)
If your cap does not blow off, then it does not have excessive blow-by. You will always see some oil vapor coming out, and the cap will always vibrate on the filler tube.
Did you ask him why he didn't let the GP's cycle? I am clueless there, and have no idea why anyone would do that.
DP-Tuner
For Your Tuning Needs
Like us on
Justin Bochmann
Sales and Technical Support
828-221-0076 ext.804
Justin@DP-Tuner is offline
post #4 of 4 Old 02-26-2013, 02:30 PM Thread Starter
slowcoupe's Avatar
Quoted: 11 Post(s)
Yea see I have been reading that a ping pong ball could be used to verify if there is excessive pressure but it says nowhere about plugging the ccv hose. So I am curious is to why the CCV hose was plugged. Because of course that's going to cause an increase in pressure and that's what causes seals to go.
And I didn't ask about the GP thing. I just let him do his things and waited to hear what he had to say.
-7.3/ZF6 combo.
-TS tuned
-DJM 3/5 drop
COMING SOON
-Midwest shifter
-DP tuner
