  #21 (permalink)
Old 12-29-2007, 04:04 PM
najaf4life najaf4life is offline
Look Ma.. No Hands
I have it set around 1350.... but when I really wanna play I just hit the enter button twice real quick and you can disable the backdown feature up to 30 mins. I beleive... and holding the break and flooring it awell it will smoke for a sec or two then the turbo will catch up.. best way is just to drive it and floor it....
  #22 (permalink)
Old 12-29-2007, 04:12 PM
somebodyelse5 somebodyelse5 is online now
ok. i brought all of my parameters down a bit just to be safe. Im going to try again and see if i can get her to throw some coal. ill let you know how it goes.
  #23 (permalink)
Old 12-29-2007, 04:19 PM
Look Ma.. No Hands
like I said try setting the low boost level to 5 (most responsive) and disable the backdown feature...
  #24 (permalink)
Old 12-29-2007, 06:40 PM
strokin_early_99 strokin_early_99 is offline
John Wood Nut Swinger
Somebodyelse,
I will keep this simple. Start a thread about injectors and what are needed to support them. Don't hang your hats on one persons statement.
Keep Strokin'
  #25 (permalink)
Old 12-29-2007, 07:21 PM
shadowe123 shadowe123 is offline
i just got a dp with 60 tow and 80 eco... its such a difference..i love it but like i asked earlier how do you keep it smoking it seems like after a couple seconds it stops is it because the turbo takes over????
  #26 (permalink)
Old 12-29-2007, 08:10 PM
Smoke is unburnt fuel. The reason it don't smoke long is because the turbo is pumping enough air by then.
If you only want smoke, put a piece of plastic over the intake, someone else said before.
  #27 (permalink)
Old 12-29-2007, 08:28 PM
ohhhh ok.... i didnt know that... thanks
  #28 (permalink)
Old 12-29-2007, 08:40 PM
Shadow, what kind of gauges are you running?
  #29 (permalink)
Old 12-29-2007, 08:42 PM
none i need some bad...
  #30 (permalink)
Old 12-29-2007, 10:05 PM
CattleHauler CattleHauler is offline
cover it with plastic?...why not just dump a quart of oil through the turbo?
...that'll make it smoke like an old coal train
P.S.- ^^^DON'T DO THAT!
