  #11 (permalink)
Old 12-29-2007, 01:38 PM
najaf4life najaf4life is online now
Look Ma.. No Hands
no you don't need a hpop to keep the injectors running... it just depends on what size of injectors you get and for the jucie smoking it should smoke pretty darn good... my juice smokes more than my TS.. quite a bit more actually.... and yes adjust the low level boost to 5 (more responsive) and it will smoke like you want
  #12 (permalink)
Old 12-29-2007, 02:31 PM
somebodyelse5 somebodyelse5 is offline
naja do you run injectors with your juice? Mine really doesnt smoke much and its kinda disapointing.......
what size injectors would you recommend and what site would you buy them from?
  #13 (permalink)
Old 12-29-2007, 02:43 PM
Look Ma.. No Hands
no I don't have injetors.... some day I will but not yet... if I was you I would only go with some stage ones unless you want to get big oil and other things to help the injectors out (turbo, intercooler, etc.
  #14 (permalink)
Old 12-29-2007, 02:45 PM
Look Ma.. No Hands
well look at my videos and you can see my TS and my Edge... and you can see the Edge smokes alot more YouTube - Broadcast Yourself.
  #15 (permalink)
Old 12-29-2007, 02:49 PM
no i would only go with stage 1 then. what are you doing to your truck to get it to smoke. because iv only gotten it to smoke a little.
  #16 (permalink)
Look Ma.. No Hands
nothing... just letting out the clutch then I floored it... did you change your low boost setting?
  #17 (permalink)
Old 12-29-2007, 02:53 PM
shadowe123 shadowe123 is offline
im about to get some injectors can anyone give me advice on which ones i should use...
  #18 (permalink)
Old 12-29-2007, 03:49 PM
wrong thread shadow we are talking about chips.
I have the low boost fueling set to 5(most responsive) I also have an auto.... would that make a difference? and i still have stock exhaust.
I watched your videos... the edge smokes alot more than your ts... i cant figure out why mine isnt smoking like that!
  #19 (permalink)
Old 12-29-2007, 03:53 PM
Look Ma.. No Hands
well yeah it would make a difference a little cause I can bog my truck down to roal the coal.... but you should get the same result from flooring it just at first.... and shadow don't worry you can if you want
  #20 (permalink)
Old 12-29-2007, 04:01 PM
ok, i floored it last night in lvl4 and it chirped at me and backed down 20%. whats your egt backoff parameter set at? and do you have a problem with the engine light set on.
Would holding the break and letting the turbo spool up create more smoke?
