  #11 (permalink)
Old 12-29-2007, 12:07 PM
strokerboy73 strokerboy73 is offline
When i am in OD and pulling and hill with our 25ft gooseneck and skidsteer. The waste gate makes like a "flutter noise" kinda like what you have described. From what i was told it is just releasing pressure. It has reached max boost and dumps the excess. not sure if thats right but thats what i am told.
  #12 (permalink)
Old 12-29-2007, 08:11 PM
99copperhead 99copperhead is offline
i have this problem with my 99 so any help would be nice i have unhooked the vacum to the wastegate just to see and it still does it and mine also comes through the intake sounds like the stall issue would be more correct would a wicked wheel help this issue
  #13 (permalink)
Old 12-30-2007, 07:30 AM
boostedh22a boostedh22a is offline
Send a message via AIM to boostedh22a
This definitely isn't a problem that is expected or right. Something is wrong, it just started doing it, and my old 7.3 TD never did this.
So yeah, the more input the better. Next time I pull the trailer I'll make sure I have my boost gauge hooked up and report back what I find out.
Could this be related to the EBPV (or whatever it's called)????
  #14 (permalink)
Old 12-30-2007, 10:14 AM
  #15 (permalink)
Old 12-30-2007, 10:22 AM
turbotime turbotime is offline
Send a message via MSN to turbotime Send a message via Skype™ to turbotime
I reply, not in direct response to the tech question here, but rather to the content: Coming straight from experience and advice from the head tranny mechanic at our local ford dealer (who is also a close friend)..."NEVER EVER PULL IN OVERDRIVE with an automatic tranny!!!" The only thing worse that you could do is back your trailer up a hill or such loads. I promise you, this will eat your tranny quicker than you can see straight. I know that it means you can not go much over 65-70, but it is that or a $3K tranny.
On another note, gauges are so worth it when you are hauling and/or have any kind of mod.
  #16 (permalink)
Old 12-30-2007, 10:31 AM
lamarmathis lamarmathis is offline
i have a 2000 excursion that did the same thing i put a compressor wheel off a 99,same as a wicked wheel or similar whell,it makes a little more of a whistle now but got rid of the surging
  #17 (permalink)
Old 12-30-2007, 12:54 PM
Well, I have towed 50k, and I have a buddy that has towed over 100k, all in OD with no tranny issues whatsoever. We just stay very on top of tranny fluid changes, and honestly never had one tranny related problem.
