Old 12-27-2007, 06:04 PM
Cj Ford Cj Ford is offline
diff fluid
I'll be putting my truetrac in a week or so from now it requires no friction modifier since it has no clutches... can I use regular 80W90 gear oil in the sterling 10.50 with the Detroit or do I need to use the 75/140 or what ever ford recommends
Old 12-28-2007, 09:36 AM
back up top .. still need to know
Old 12-28-2007, 03:55 PM
Lord Tauk Lord Tauk is offline
Send a message via ICQ to Lord Tauk Send a message via AIM to Lord Tauk
Synthetic 75W-140
Old 12-28-2007, 04:43 PM
720Deere 720Deere is offline
Why try to save a few bucks on only a few quarts of oil? You only change it once every 10 to 15 engine oil changes and it only takes a few quarts. Go with the Synthetic that is supposed to be in there.
Old 12-28-2007, 07:21 PM
ns954 ns954 is offline
As info,for anyone with a Dana 80 rear axle.Ford recommends 75W-90 per TSB 04-16-4.
Old 12-28-2007, 09:15 PM
It has nothing to do with trying to save a few $$ at all..
I will be doing this job at my work so I can use the hoist/lift and not have to work on my back installing the detroit and setting it up..
The reason I was wondering is I have 80w90 gear oil in 45 gallon drums at the shop (in pneumatic dispensers) and if it was ok to use I would fill it up with that rather then go get 4 individual quarts and put them in with a funnel/hose...
Our shop buys all our oil bulk...
I will go get 4 quarts from napa
Old 12-28-2007, 09:19 PM
redstroker_2002 redstroker_2002 is offline
KVFD
i have heard good things about amsoil
Old 12-29-2007, 06:34 AM
brian42 brian42 is offline
I would use the same weight that Ford recommends but I wouldn't worry about the friction modifier since you junked the limited slip.
Old 12-29-2007, 08:28 PM
Just picked up 4 quarts from a local dealer of Amsoil got the severe duty 75W-140 Synthetic...
thanks
