Old 12-27-2007, 09:44 AM
onecrazyblackredenck onecrazyblackredenck is offline
do I need to replace
Do i need to replace the gasket on the valve body when installing my new one? do I use mercon III or Mercon V? What is the best local bought brand to get for my truck ? full synthetic?
Old 12-27-2007, 09:55 AM
KILLER KEN KILLER KEN is offline
HI, IF YOUR CHANGING OUT THE "VALVE BODY" THEN I WOULD PUT IN A NEW GASKET. IT SHOULD COME WITH ONE I WOULD BELIVE. IF YOUR TALKING ABOUT THE TRANS PAN THEN THE GASKET IS REUSABLE. IF YOU HAVE THE 4 SPEED OVERDRIVE TRANS THEN IT WOULD BE THE MERCON 5. IF ITS THE 5 SPEED OVER DRIVE THEN ITS THE MERCON SP FLUID. I WOULD GO RIGHT TO THE DEALER FOR IT. I HAD A HARD TIME TRYING TO FIND THE SP AND THE TYPE 5 TO A DEGREE, THE DEALER IS YOUR BEST BET. KEN
Old 12-27-2007, 10:20 AM
sleeperstroker sleeperstroker is offline
if youre talkin about the vb gasket leave it there unless its torn or cracked. pullint the seperator plate in the vehicle sucks because of the check balls that come out when you do it. then you have to know their locations get some trans grease and put em back in.
Old 12-27-2007, 10:26 AM
GOOD POINT, I HAVE NEVER HAD ANY LUCK WITH THE OLD GASKETS LIVING AGAIN, THEY ARE SO THIN LIKE PAPER, BUT HEY YOU NEVER KNOW. GOOD LUCK.
