Old 12-27-2007, 03:29 AM
tech701 tech701 is offline
Torque Converter Question
Is'nt there a way that a manual switch can be installed to lock the torque converter up in my 4r100. Is this bad for the tranny?
Old 12-27-2007, 03:44 AM
twildman twildman is offline
Yes, you can put a lockup switch on it, and no its not bad as long as you don't leave it locked at too low of a speed. All you have to do is locate the plug on the passenger side of the tranny, get into the wire loom and find the purple wire with a yellow trace, and tap into it, then run that wire up into the cab and put it on a switch and then run a wire to ground so that when you flip the switch it will ground the signal to the t/c and lock.
Old 12-27-2007, 06:43 AM
strokin_early_99 strokin_early_99 is offline
John Wood Nut Swinger
Pin 54 on the PCM is the same wire, purple(violet) w/ yellow, you are looking for.
Old 12-27-2007, 12:20 PM
Motown Fire Motown Fire is offline
PIN 54??? where is that on the pcm???
