Window stalls out while going down? - Ford Powerstroke Diesel Forum
Old 02-23-2013, 11:59 AM
It does it worse when cold than it does when its hot. When you try rolling the window down(drivers side only) it act as if it gets in a bind and stops. I pulled the door panel off and it looks like it is hanging up on the felt rail lining. If you pull back a little on the window (towards the rear of the truck) it will roll down fine. You can actually see the felt move a little as it grabs the felt. Is there a lube I can put on this with out getting it all over the window? Thanks!
Old 02-23-2013, 02:27 PM
Well not sure how long it will last but I took some garage door tract lube and sprayed some of it on the felt/tract. Its a non runny lube and seems to have done the trick. Works great now. Flys up and down now!
Old 04-18-2013, 09:56 AM
I used a good silicone based lubricant to fix the same problem. Going on a month now and still no problem. If I remember correctly it was Liquid Wrench brand.
Old 04-18-2013, 01:01 PM
Thanks. So far its still working like new BUT if it starts acting up I give that stuff a try.
