Old 12-26-2007, 04:26 PM
midtndiesel midtndiesel is offline
Fuse diagram?
Just bought a 2000 F250 7.3l diesel, love it. BUT it didn't come with a manual. I thought it could be found in a Haynes manual, but not luck. I cannot believe that with all the Hayne's wiring diagrams and technical data, they neglected to print even a simple fuse diagram. Which fuse goes to what? Wish I knew. Could someone PLEASE scan a copy out of your manual and post it here. I did some searching on here already, couldn't find anything. Please post a fuse diagram (both under the hood and in the cab fuse panels). Thanks in advance!
Chandler
Old 12-26-2007, 04:27 PM
redstroker_2002 redstroker_2002 is offline
KVFD
the fuses should be on the back side of the panel cover!
Old 12-30-2007, 10:21 PM
You'd think so but they are not. Come on, someone on this forum has to have a manual for a 2000 F250 they can scan and post here right?
Old 12-31-2007, 04:21 AM
silverF250 silverF250 is offline
I'll try an get it to you today might need to get your e-mail though.
Old 12-31-2007, 04:27 AM
wetco416 wetco416 is offline
https://www.fleet.ford.com/maintenan...ls/results.asp
Old 12-31-2007, 04:59 AM
jblz51 jblz51 is offline
Do you have a high speed internet connection? If so, then the link above is what you need. The fuse info is on pages 149-154. If you don't have high speed, let me know, I will scan those pages in and send them to you.
Old 12-31-2007, 08:41 AM
Thanks for the help guys, that ford link worked great! I appreciate it!
