more problems upper ball joints - Ford Powerstroke Diesel Forum
Old 02-22-2013, 04:29 PM
Well more problems, took the truck to get the front end aligned and they said the upper ball joints need replacing. I moved the wheels up and down, maybe 1/8" of play maybe a tad more. How bad is this? I don't drive this truck much, just to the dump or during bad weather so I wont get stuck. Truck drives good, does not wander around on the road. I just got through replacing the wheel bearing hub on the drivers side and didn't feel the upper ball joint prob. But i felt it after driving it 25 miles to the align shop. Need opinions please!
Old 02-22-2013, 06:29 PM
Well it's not good. I would def fix them. They will only get worse and there is a lot of weight on them. It will effect your tire wear and other suspension components as well.
Old 02-22-2013, 08:10 PM
Yeap that's not good. Might as well replace the lowers while you're at it.
Old 02-23-2013, 04:50 AM
That's what I figured, thanks.
