Old 12-25-2007, 09:08 AM
illness illness is offline
engine out.. now what?
i'm planning on removing my engine soon so i can replace the oil pan.
i'm looking for suggestions like,
"while you have the engine out you better change the __________"
"its easier to do _________ while the engine is out"
so far i'm replacing:
oil pan
rear main seal
exhaust manifolds gaskets (the bolts are rusted bad so if figured i'll beat them before they beat me)
thanks in advance for the help.
Old 12-25-2007, 09:14 AM
redstroker_2002 redstroker_2002 is offline
KVFD
i am not forsure!! i would clean the engine up while i had it out!! good luck to ya send sum pics our way
Old 12-25-2007, 09:16 AM
WEWILLE WEWILLE is offline
ready for spring
How many miles are on it?
Old 12-25-2007, 09:18 AM
benderado benderado is offline
HEADSTUDS!! Only if your making big power of plan on making big power sometime in the future.
Old 12-25-2007, 09:27 AM
alabamafrog alabamafrog is offline
Powerstroke Techie
The guys at Swamps advised me to remove the piston cooling jets and tig weld the tubes into the bases while I had the oil pan off. It was easy to do and would be a real pain to fix if one of them fell off. Here are the pics of my engine job if your interested. Shutterfly | View Shared Pictures
Old 12-25-2007, 09:29 AM
forddieseltweek forddieseltweek is offline
Old 12-25-2007, 01:23 PM
NJStroker NJStroker is offline
I will tell you that I would not replace the rear seal unless it is leaking. Messing with that will increase your chances for a leak in the future. The advice I got when I replaced my oil pan was, "If it's not broke, don't fix it". That has worked for me.
Old 12-26-2007, 07:48 AM
strokin_early_99 strokin_early_99 is offline
John Wood Nut Swinger
What mods do you have done to your truck already and what is your power goals with the truck?
First thing that comes to mind is headstuds and valve springs if you are looking to make 40+psi of boost.
Old 12-26-2007, 02:07 PM
it has 130,000 miles
interesting theory on the rear seal....anyone else agree?
very interested in welding the tubes into the bases. can this be done with a mig? i can tig but do not have a tig machine at my current job.
i just got the truck. i traded my 1993 mustang for it straight up. its been in my yard for 3 weeks; i'm waiting for the holidays to pass so i can start.
i don't plan on making crazy power. maybe intake, exhaust, whatever lowbuck mods i can learn from here, and maybe a programmer.
Old 12-26-2007, 02:13 PM
fordmt fordmt is offline
Don't turn the engine upside down until you get the oil pan off-----you will risk getting all the garbage that has settled at the bottom of the pan into your high pressure oil system.
Mike Cleary
Owner/Educator/Technician
Automotive Technical Support Services
Specializing in Ford Vehicle Systems Training
P.O. Box 27522
Fresno, CA 93729
Welcome To Mike Cleary's Automotive Technical Support Services
