Banging sound what did I do? - Ford Powerstroke Diesel Forum
Old 02-21-2013, 07:51 PM
Today while pulling out a stuck bus the truck started blowing a ton of black smoke then started doing this.
what did I do? Also earlier in the day the truck threw 3 or 4 ebpv codes but after clearing them they never came back.
Old 02-21-2013, 08:18 PM
Checking the connections on the UCVH. Sounds like only one side is firing?
Old 02-21-2013, 09:34 PM
how can I test my injectors? Also would a spun rod make that noise?
Old 02-21-2013, 09:58 PM
That's quite the noise. Smoke at idle? A bad injector can cause you to knock like hell, and smoke like crazy. Also it'll burn up your engine very very fast if you keep running it.
That one is smoking like hell but yours may not, sounds the same though. Tips can break off or stay wide open. I even found a thread where it hydrolocked one guys motor.
I'm assuming you drove it home after, how was it on power and smoke under normal driving. Check engine light?
As far as a test I would pull both valve covers and run the engine, unplugging the injectors one by one ( itll run on 7 no problem) Start with #8 which is the drivers side rear, you'll know the second you unplug the right one.
The proper way to do that is build a breakout box like in this thread, but many people including myself have unplugged them without issue. You could also shut off the truck each time and unplug but I was alone when I did it.
http://www.ford-trucks.com/forums/62...with-pics.html
Sorry for linking another forum if that's not cool.
A buzz and contribution test will probably find a bad injector, but not always. A knock like that should be easy to tell by just unplugging.
Old 02-21-2013, 10:07 PM
That sounds just like it. Damn thing sounds like your beating on a tin can. It was low on power and i only drove it another mile or so. My buddies behind me said it was pouring smoke. They couldnt tell if it was blue or black though because it was to dark outside.
Old 02-21-2013, 10:12 PM
7.3 powerstroke knock? - YouTube
This kind of scares me though
Old 02-21-2013, 11:16 PM
Yeah but the pouring smoke would make me lean to injector(and hope)
Old 02-22-2013, 01:02 AM
Just don't drive it untill you get it figured out.. A tow bill is cheaper than the retardly high EGT's you'll be seeing if it is you injector pouring fluid.
Old 02-27-2013, 08:36 PM
Ok I pulled the valve covers and found a broke exhaust rocker arm. Whats the best way to check for lifter and valve damage
