I own a 2000 F250 with a 7.3. I have a coolant leak that is driving us nuts. Checked all hoses,done a pressure test on the system,and the only leak found was the hose between the radiator and overflow tank which was replaced. Stil leaking. Anyone have any suggestions ? Thanks.
Are you just missing coolant or is there antifreeze on the ground?
water pump weep hole was my culprit.
Antifreeze on the ground under the front of the oil pan. Did you have to change out the water pump ? This is my first diesel so I am learning on the fly. Thanks.
Yeah. I had unknown coolant loss for a while. I thought it was getting into my oil, but after I replaced the water pump I got a good look at the weep hole and it was all stained up from coolant leaking for a while. I went with dieselsite's water pump, good price and lifetime warrenty.
I got under the truck today. Nothing leaked out while the truck was shut down. Didn't drive it today. I looked up around the water pump with a light. Hoses all look fine,lower elbow wasn't leaking,the only place I saw coolant was under the water pump down the front side of the oil pan.
Time for a new water pump
Did you pressure test the cap? Doesn't the overflow hose dump in front of the motor?
I've read that the caps commonly hold little, if any, pressure. |
We did a pressure test without any coolant leaking. The last couple of nights there has been a small amount of coolant dripping. I am guessing about four ounces,maybe a bit more. It only seems to be leaking at night as each time I am driving at shutdown I check to see if it is leaking I see no coolant leaking. My mechanic told me today he thinks it may be leaking at the timing cover. he said it is a big job to repair. Any suggestions ? Thanks.
i would get a new mechanic. i would bet on water pump.
http://www.dieselsite.com/1996-2003f...waterpump.aspx |
