Old 12-22-2007, 06:06 PM
tubular031 tubular031 is offline
Wandering at 55+
Lately when I am driving around 55+ my truck seems to wander all over the place. I spend lots of time and effort moving the wheel from side to side trying to keep the truck going straight in my lane. What could this be? Time for a new steering box? Maybe tierods?
Thanks guys
Old 12-22-2007, 06:58 PM
chrispaine chrispaine is offline
I have the same problem, I already turned in the adj on the box one turn and checked the ball joints and they are good... still could be alot better.
Old 12-22-2007, 08:53 PM
What do i need to do to adjust the steering box?
Old 12-22-2007, 09:08 PM
there is a torx with a set nut around it in the center of the steering box that you can adj. just break the nut loose(pait mark first so you know where you started) and turn the torx in no more then a full turn, some people say no more then a 1/2 turn. and then snug the set nut back up.
Old 12-22-2007, 09:45 PM
greenie greenie is offline
Thumbs up Wandering at 55
Man thats serious....................I had the same problem so i changes out the steering linkage.I got moog and connected them to each wheel and steering box.Had em aligned and bam..........I can drive 55 + with no hands.Cost at Oralleys was about 450.00.I greesed the bearings and did the breaks as well. It sur takes the white nuckels out of fear man.
Old 12-22-2007, 10:38 PM
strokin_early_99 strokin_early_99 is offline
John Wood Nut Swinger
Are you sure it is a torx? Mine is an allan.
Check your track rod bolts and your pitman arm nut also.
Old 12-22-2007, 10:46 PM
2005F250 2005F250 is offline
Are you the one with the Canadian truck?
Old 12-22-2007, 10:49 PM
Yah, why? Are you going to pick on me now?
Old 12-23-2007, 06:31 AM
what in the linkage did you end up changing out? everthing? or just the tierod ends or the pitman arm or what?
Old 12-23-2007, 03:02 PM
that is a nice pic. I am with chrispaine, What parts did you swap out?
