Overhead console failed - Ford Powerstroke Diesel Forum
Old 08-22-2006, 02:12 PM
ETM ETM is offline
My overhead console / trip computer has failed. One day the readings appeared dim and the next day no LCD. Checked fuses, brightness dial.
Once I have some water drip from it. Probably a leak from the roof light above it.
How do I remove the console from the ceiling? Does not appear obvious.
Any other advice?
ETM
Old 08-22-2006, 03:28 PM
International Threat
Just pull straight down... will sound like it's breaking but it's just the clips letting loose... someone had my truck before me and used some adhesive to hold the clips in place and I broke minne while taking it out...
Old 08-22-2006, 03:29 PM
There was a thread on this subject a while back. I believe it just snaps in place. One of the Guru's should be along shortly to help you out.
Old 08-22-2006, 04:21 PM
yup, just pull strait down, but like marty said, it will sound like it broke when the snaps release.......but it shouldnt if you pull strait down..
Old 08-22-2006, 05:54 PM
ETM ETM is offline
A few carefully redone solder joints and all is well again. Thanks, ETM
Old 08-22-2006, 07:14 PM
I found this on another site, I hope it helps.
http://www.ford-trucks.com/forums/44...erhead+console
