EXHAUST BACKPRESSURE! - Ford Powerstroke Diesel Forum
post #1 of 13 Old 12-20-2007, 06:20 AM Thread Starter
larz18's Avatar
Does anyone know what the maximum exhaust backpressure is for the 7.3 motor. I would like to know the pressure in psi if possible. I have found a couple different things about it, one site said maximum 250 hp backpressure and then i found a maximum of 60psi on another site but it was for a different motor. I'm sure they are all different. Is there a way to convert the 250 hp to a psi?
Please help
thanks
GO GO BIG RED!
Sniper Tuner, RDP 2-stage water meth, ZEX NOS kit, 7 Autometer gauges, coolant filter, Trans lockup, High Idle mod, JOHN WOOD Full Billet Trans, TWINS! Holset HX-35/40 hybrid over HX-52 Pro Turbo, 255/200 II Hybrids, Adrenaline HPOP LPOP, 6 Stage Injector Pressure Module, 4" straight piped, Mag-Hytec Covers, RDP exhaust brake, DI Regulated Return, Aeromotive Fuel pump, Fuel Bowl Delete, Dual Tranny coolers, RDP Track Bars, SpynTec Conversion, 4.11 Yukons, 6" procomp lift
larz18 is offline
post #2 of 13 Old 12-20-2007, 06:48 AM
John Wood Nut Swinger
strokin_early_99's Avatar
Are you looking for the point the drive pressure will float the valves or when it will set a code?
With a drive pressure (back pressure) of 64psi my truck will set a SES lite.
(Born on 11-20-98) F350 CC LWB 4X4
north of 480hp and south of 13.7sec
Bored with current setup
Family of 5 saved by Grace.....
Sponsored by Left Coast Diesel in Concord, Ca
Anything BUT Conservative Performance
strokin_early_99 is offline
post #3 of 13 Old 12-20-2007, 07:01 AM Thread Starter
larz18's Avatar
I'm after the MAX allowed before it screws up the motor.
I don't care if it sets of a code. Just need the max so i dont screw up something.
Or is there a max? If it gets to much backpressure then the engine will just stop right?
But i guess if it gets to high it could bend a piston or something.
GO GO BIG RED!
larz18 is offline
post #4 of 13 Old 12-20-2007, 07:03 AM Thread Starter
larz18's Avatar
i guess all im after is to hold open the valves for exhaust braking but again i dont want to screw up the engine.
GO GO BIG RED!
larz18 is offline
post #5 of 13 Old 12-20-2007, 07:11 AM Thread Starter
larz18's Avatar
Strokin: So you do monitor your backpressure? And i'm assuming you have an exhaust brake? Does your exhaust brake all minimal air through or do you shut off the flow completely? i was thinking of putting in a spring with a bypass valve that opened up at 60psi or monitor it and if the pressure goes up to high i can just open it up a little.
What you think?
GO GO BIG RED!
larz18 is offline
post #6 of 13 Old 12-20-2007, 07:31 AM
CSIPSD's Avatar
What are you useing for an exhaust brake? As far as a Max that is going to depend on many things... Under load it will be higher, but under no load it will be lower...
01 F-250 SC PSD,320k,16 Isspro Gauges, AFE-2,CCV Mod,IAH delete,map reg,Modded H2e, 6.0 IC, 230/100 from P.I.S, Studs, 910 springs, Forged rods, Water injection,Hydra chip-No Limit/Gearhead tuning, Swamps HVHF IDM, MBRP 4" dual's, Aero, 6" tip's, 4" Revtek lift, 37/12.5/16.5 MT's
Joe
DYNOPROVEN.COM, PERFORMANCEINJECTIONSYSTEMS.COM and RIFFRAFFDIESEL.COM
CSIPSD is offline
post #7 of 13 Old 12-20-2007, 07:40 AM Thread Starter
larz18's Avatar
I have built my own using a 4" cast iron butterfly valve which is used in compressed air applications and an electronic linear actuator. I know the pressure will change depending on load, i just dont want to overdue it.
GO GO BIG RED!
larz18 is offline
post #8 of 13 Old 12-20-2007, 07:46 AM
CSIPSD's Avatar
Your playing with fire there... But take a look at the factory EBPV. It has a hole in it to help with the back pressure. With an exhaust brake I would not want to have more then about 50#'s back pressure...
Joe
CSIPSD is offline
post #9 of 13 Old 12-20-2007, 07:46 AM
CSIPSD's Avatar
And with too much back pressure your not going to bend a piston or rod, your going to float a valve and bend it or the pushrod.
Joe
CSIPSD is offline
post #10 of 13 Old 12-20-2007, 08:14 AM Thread Starter
larz18's Avatar
I no longer have a factory EBPV, do you have a pic or know the size of the hole
GO GO BIG RED!
larz18 is offline
