MPG took a major drop, NEED HELP - Ford Powerstroke Diesel Forum
Old 02-16-2013, 07:33 AM
ive got a 99 7.3 crew cab dualley 2wheel drive with 100k miles. about 2 months ago i noticed a fuel smell and started seeing pudles. found out it was the o-rings in the fuel bowl, so i searched on here and bought the o-ring replacement kit. replaced ALL the o-rings, fuel smell is gone and no more pudles. but now my mpg is horrible!!!
truck is 90% stock, MBRP SS exhaust,NAPA filter mod, CCV mod, nothing major.
any advise or reccomendations as to whats going on?
Old 02-16-2013, 12:53 PM
clean the EBP tube.
Welcome to guzzle's Exhaust Backpressure Sensor Cleaning Maintenance Web Page
Old 02-16-2013, 04:14 PM
My mileage has significantly declined over the last little while. I cleaned the EBP tube to no avail.
I've determined that its time for injectors for me
Old 02-17-2013, 06:09 AM
ok thanks. ill try the EBP cleanout.
how do you know you need new injectors??
Old 02-17-2013, 08:10 AM
Injectors wear out eventually. I'm getting to the point in mileage where they are due.
Worn injectors cause slower starting, rougher running, and poor mileage - all symptoms my truck has developed.
Old 02-17-2013, 08:16 AM
i found a problem, the copper tube has a hole worn in it. but it looks like its been there. hopefully it fixes my problem.
now i have to find a new tube
Old 02-17-2013, 09:04 AM
Feedback Score: 3 reviews
DieselOrings: Exhaust Back Pressure Replacement Tube 99.5 - 03 7.3L Diesel
Old 02-17-2013, 10:20 AM
^^ got it thanks
i ordered a new tube and the senser just to be sure
Old 02-17-2013, 11:21 AM
Just another configuration for you guys is that you're all non winter diesel, it makes my miles per gallon go for about 10 to 12 down to 9 to 10... Just an idea there might not be anything wrong other than it is winter blend
Old 02-17-2013, 03:05 PM
thats what i was thinking. when i bought my truck i was getting around 15-17 now its down to 12-14
