Weak HPOP?
No real problems with the truck it has just always seemed a little weaker than most of my buddies trucks. Ran my ae on a WOT run today and got this...
accl RPM EXBP ICP ICP-dc
Is it getting weak? 317,000 miles. Thanks Last edited by floorboy; 02-15-2013 at 10:00 AM. |
It is either a weak HPOP or you are loosing oil pressure somewhere else. Your duty cycle is way up there so it is trying and calling for more oil.
KOEO was 14.82 if I remember? Idle? 500 something maybe?? Where to look? Injectors? Not sure how you tell. Thanks.
Could bad injector orings cause this?? I was told I should replace my orings with my mileage last year by somebody on here. I bought them but never got them installed.
That's a cheaper option than replacement of the pump. And if you do the o-rings you know for sure after that. With that many miles I'd guess it's weak, and o-rings are weak too.
I do not think you would be losing that much ICP through a worn injector o-ring. Although at 317,000, it is probably a good idea to change them.
what causes the icp to spike like that when you let off the throttle?
It sounds like you're losing fuel pressure. My trucks icp spiked when I let off the throttle. It happened when my in tank screens were plugged
