wastegate closes while driving - Ford Powerstroke Diesel Forum
Old 02-13-2013, 01:28 AM
We have a 2000 f350 at work and I have noticed that the wastegate (?)is closing while we drive. When you let off the throttle then get back on it slightly you can feel a lag and you can hear it surging and then it will open and the truck runs fine. Is this normal? If not what is the fix? I've only noticed it since it has been cold out.
Old 02-13-2013, 04:07 AM
Re: wastegate closes while driving
Not wastegate. It is the Exhaust Back Pressure Valve EBPV doing its job... perhaps not properly but none the less... my 2000 dually and Excursion do not activate like that but my early '99 does make hiss while driving at times.... part of the early/late diffrences.
Sent from my SCH-I200 using AutoGuide.Com Free App
Old 02-13-2013, 04:40 AM
Winter Operation, Hard Starting, Hissing Sound Etc...
Old 02-13-2013, 10:23 AM
I knew it wasnt the wastegate but couldn't remember the correct name. I can't imagine that is good for it. Is there an adjustment? I would think it may be killing the fuel economy.
Old 02-13-2013, 11:05 AM
There is no adjustment, but you can delete it if you want.
Old 02-13-2013, 11:19 AM
Nah, theres no deleting it. Boss won't go for that. Besides it works well on cold mornings here in pa. Whers is it located?
Old 02-13-2013, 11:28 AM
The valve is located in the turbo pedestal and the flapper is located in the exhaust outlet on the turbo.
