Need Help!!! - Ford Powerstroke Diesel Forum
post #1 of 4 Old 02-12-2013, 07:03 PM Thread Starter
bieryjake's Avatar
Need Help!!!
I have half a tank of fuel in a truck I'm getting rid of and need it for my new truck. How can I drain the fuel out of the tank without putting a hole in the tank?
bieryjake is offline
post #2 of 4 Old 02-12-2013, 07:18 PM
Can you put a hose on the fuel drain tube from drain valve on the the fuel filter bowl and turn the key on?
99 F350 4x4 7.3 6 speed w/480K
02 F250 4x4 7.3 Auto w/490K
00 Excursion 4x4 V10 w/140K
F350none is offline
post #3 of 4 Old 02-12-2013, 07:33 PM
Behavior Modificationist
AgTires4295's Avatar
Quoted: 19 Post(s)
Grab a hose of some length, place it in the tank, put the end of the hose in a large container of some sort and drain the fuel by using gravity. You will have to get it started by creating a vacuum to get the diesel beyond the highest point. Once it's flowing, it will continue to flow until air bubbles eliminate the vacuum-like effect, so be ready.
2001 7.3L
Pro Comp 6.5" Lift
Pro Comp 16x10 Alloys
35x12.5 Nitto Mud Grapplers
Sky Jacker Hydro 7000 Steering Stabilizers
K&N CAI JUNKED For A 6637
Straight Piped Dual 4"
Jasper 4R100 (Rebuilt in '05)
Tru-Cool Max
Dieselsite Coolant/Trans Filters
ISSPRO EV2 (Boost, EGT, Trans)
Centramatics
EBPV Switch
'07 Headlight Conversion
Foil Delete
Zoodad
Monitoring with Torque
AgTires4295 is offline
post #4 of 4 Old 02-12-2013, 07:39 PM Thread Starter
bieryjake's Avatar
I'm curious toward this method. Just pump until the low fuel light comes on?
