headligt issue - Ford Powerstroke Diesel Forum
Old 02-11-2013, 03:17 PM
headligt issue
im new here but i just recently bought a 02 ecsb 6 speed diesel and it had this aftermarket headlights with leds in the middle and HIDS for the headlights, so the other day i hop in to turn on my headlights and nothing so i said screw it ill drive and hope they work well i flickered with brights lever and boom they worked so i felt risky and shut my lights off then back on and now nothing just the marker lights and everything else i checked bulbs relays and fuses and they are all good so do you guys have any idea on where else to check?
Old 02-11-2013, 03:34 PM
00-04 Ford Excursion, 99-04 F250 Super-duty LED Headlights with Amber Reflectors - Pair (Chrome)
this is what the headlights are
Old 02-11-2013, 08:09 PM
I would suggest pulling the headlight switch and see if it has gotten gooped up? If fiddling with the hi/lo selector switch let them come on then that could be suspect and you could open the column up and clean the hi/lo switch and look at the wires. I am not sure what the voltage requirement for the lights you have might be, but due to a build up of crud the switches could be causing a voltage drop just low enough so the lights do not come on.
