zerex or final charge? - Ford Powerstroke Diesel Forum
Old 02-11-2013, 12:19 PM
I will be replacing my oil cooler and water pump here shortly and figured why not finnaly get around to swaping out the green crap for the elc-1 rated stuff. I wanted to get the rotella elc, but don't have anything local. Just wanted to see if you guys think either one of these options are better than the other and what your thoughts are on it. thanks
One is 25 a bottle for concentrate while the other is 14, not sure the 14 is concentrate though, gonna have to check on that. These are the only ones that I have found locally.
NAPA AUTO PARTS
or
Antifreeze/Coolant Peak HD FINALCHARGE - Engine Coolant / Anti-Freeze | O'Reilly Auto Parts
thanks
Old 02-11-2013, 12:25 PM
Zerex from napa is about $14 it sounds right.
Old 02-11-2013, 12:47 PM
Thanks, I just thought it was off because the 50/50 mix is only 2 dollars cheaper. Do you have an opinion on one over the other, zerex or final charge?
Old 02-11-2013, 02:22 PM
i think zerex is fine.
i bought 4 gallons of fleet charge from tractor supply hardware.
then just picked up 4 gallons of distilled water and good to go.
i think i spent about 74 bucks total for everything.
Old 02-11-2013, 02:36 PM
Send a message via AIM to dieselmatt
I use Zerex in my 6.0 and I haven't had any issues with it.
Old 02-11-2013, 04:41 PM
Fleet charge is not ec-1 rated final charge is both made by same company though i made same mistake running fleet charge right now but will change to a cat ec-1 rated antifreeze someday
Old 02-11-2013, 04:45 PM
Fleet charge? Zerex or final charge, both meet or exceed cat ec-1 rating
Old 02-11-2013, 04:47 PM
I use the Peak brand, the Final Charge Global.
Old 02-11-2013, 05:08 PM
I was talking about this post
Old 02-12-2013, 04:20 AM
Sorry about that, I must have missed that. Thanks
