Tranny filtration
i do a tranny flush and filter change every 50k but i keep thinking i should add an external filter. i have been looking at the kit from dieselsite.com
any suggestions? |
I did a DIY exactly like theirs. I wish I woulda just bought there's
![]() I would use it. It never hurts, and they're cheap filters. Also, in 32k miles, I haven't needed a new filter yet, but I also flushed right before that too. |
here's mine..copied the idea from here...i cut the to/from hardlines, tapped into them, bent new aluminum lines to lead up to/from filter
SpringerPop's Transmission Filter Last edited by timmyboy76; 02-10-2013 at 02:51 PM. |
That one looks good.
The issue with a DIY using the out line from the trans to cooler is you're running right by exhaust. So I had to find/buy some heat wrap for my rubber lines. The DS braided SS lines are wonderful. |
that's the thing, i want it for piece of mind but is it really needed? your not far from a complete flush. i guess filtering is always good but...
Personally, I think it needs it. Allisons have them.
The normal filter is a joke; the magnet does most of the work. If you tow a decent amount or have a heavy body on the truck, definitely. City driving, yes. |
I have a Fram HP1 and mount and Derail t-stat I am planning on adding as soon as I can save up for the JW Valvebody. I would like to do it all at the same time.
Ryan |
