Old 12-09-2007, 04:11 AM
mktchevelle mktchevelle is offline
Filler neck size
Is there a filler neck with a larger hole to take the bigger nozzel the big trucks use? Sometimes it is hard to find the smaller pump nozzels.
Old 12-09-2007, 05:23 AM
Dave Dave is offline
Obama sucks
yes there is just get one from an 01 or newer truck. Mine has one stock
Old 12-09-2007, 08:26 AM
strokin_early_99 strokin_early_99 is offline
John Wood Nut Swinger
Take out your filler neck and drill it out. It will save you $85 for a new filler neck. I needed one because mine broke. I did not know about the year difference. But I took my new neck and pulled the metal flapper out and used a hole saw to open it up to the size I wanted. Then washed it out with parts cleaner and compressed air.
