Old 12-08-2007, 11:22 AM
Black Pwrstroke Black Pwrstroke is offline
PSDconvert to cummins
SO i was thinkn about putin a cummins in my 02 psd but do you think i should just get like an old 3/4 ton obs and make it a project truck instead tearin my 02 apart.
Old 12-08-2007, 12:17 PM
dieselcrawler dieselcrawler is offline
Project trucks are always nice... not havein' to worry how yer gonna get to work come monday... OBS trucks look cool, havin' a cummins under the hood would catch my attention...
Old 12-08-2007, 03:54 PM
Ya thats what i was thinkin even though im a homeschool student yet i still dont what my truck in a 1000 diff. pieces for 6 to 12 months.
Old 12-08-2007, 03:56 PM
redstroker_2002 redstroker_2002 is offline
KVFD
get an obs and dont do that to your truck now!
Old 12-08-2007, 05:24 PM
strokin_early_99 strokin_early_99 is offline
John Wood Nut Swinger
Traitor!!! Wimps turn to the dark side.....J/K...
The cummins bolts into the 99-03 easier than the OBS due to the engine compartment depth, front to back. Think about it, the OBS is tough putting in a 3" DP and the SD putting in a 4" DP is a piece of cake. With a cummins you need all the clearance you can get. That engine is long and your turbo and DP are on the passenger side right where the evap box is.
Just a thought, Bean has done a few using destroked parts, might be worth a call to him for pointers.
Old 12-08-2007, 05:51 PM
slow96stroke slow96stroke is offline
cummins swap
If you are gong to do that I would go with the 12 valve. The 91, 92, 93 is the motor of choice if you are looking for speed. They come from the factory with a gnarley cam already. (The tranny has a better input shaft also....High horsepower will pop the input shafts when you hit lockup...)The downfall is the pump sucks on them. If you can find that motor and put a P Pump on it you are in buisness. The dark side is much cheaper to hop up. I am new to the psd market but know ALOT about the 12 valves. If you have any questions....just lemme know.
Old 12-08-2007, 10:45 PM
Jonathan734 Jonathan734 is offline
I have been thinking the same thing, I found a nice donor truck for 3 grand, and my motor only has 108000, I wonder how much the kit to put it in is and how much I could sell my motor for....
Old 12-10-2007, 10:17 AM
rufushusky rufushusky is offline
Send a message via AIM to rufushusky
Check out:
DESTROKED: Cummins Conversions
Auto World
and
FordCummins.com: Home
They should help you out.
