Old 12-07-2007, 11:09 PM
BigRed02 BigRed02 is offline
Northwest Stroker
Flush This
I brought my rig in for routine the other day and the service dept did the "color check" on my fluids. To be honest I only check levels. I was told my brake fluid was looking a little green and my tranny fluid wasn't as a red as he thought it should be. He recommended to have all the works flushed: motor, tranny, brake fluid. My rig has under 50k on it and I haven't acquired my 50ft camping yaht to tow as of yet, so I told him maybe next time. Any one agree with him, or do I have no reason to do any of this yet?
Old 12-07-2007, 11:13 PM
landofconfusion landofconfusion is offline
Send a message via AIM to landofconfusion
A while ago Marc, posted this, i saved it and now i shall repost it for you, but complete credit due is to Marc!
Service Manual:
first off ill state that if your truck is used hard....IE towing heavy or rough off roading...these intervals should be cut by 1/3 to 1/2........
Fluid requirments
Front diff.........80/90 gear oil
Rear diff..........75/140 synthetic gear oil...also 4oz of friciton modifier if its a limited slip...
transfercase......Standard Mercon ATF
Tranny.....E4OD/4R100(7.3 trannies)....Standard Mercon ATF.......Torqueshift(6.0)....Mercon SP ATF...and nothing other than that........ZF 6 speed requires a special synthetic available from ford
Engine oil.....15-40 (or 10-30 in cold winter areas during that time)....but make sure it says "for diesel engines"
powersteering fluid....Type F ATF if the resevour is right on the pump (7.3)....Mercon ATF if the resevour isnt right on the pump (6.0)
Brake fluid.....Standard DOT 3 fluid in all vehicles.....
Coolant....this is a touchy area....if it was green from the factory.....any green coolant will work....if it was yellow/gold from the factory...make sure to use only coolant that matches ford gold specifications and NEVER use a coolant that says its compatable with all coolants....NEVER mix coolant colors....
Service Intervals
Every 3-5K.....Oil change....Rotate tires...check all fluids and air filter (dont trust the air filter minder on 7.3's.....but it is accurate on 6.0's)
Every 15k.....change fuel filter (there is two on a 6.0) and change the spinn on trans filter that is on the framerail on the front of the passanger side on the 6.0
Every 30k....Change green coolant, Service trans (if your truck does not have a drain plug on the torque converter....some 4R100's 01-02 dont....no tranny does 03 and newer....then pull the plug on the pan and drain it at 15k....dropp the pan and change the filter 15k after that...and run that rotating interval every 15k)......service transfercase, drain powersteering fluid and re-fill (easiest to do by taking the bottom (toughtest to get to) line off of the pump on a 7.3...the one with the hose clamp....and on a 6.0.....take any line off of the resevour and drain it and the re-fill it)
Every 60k......Change Gold coolant......Service rear diff.....service front diff if 4x4 is used often....
Every 100K....Service front diff if not done at 60K......Change Serp belt and inspect tensioner.....inspect all coolant hoses.....Service manual (ZF 6 speed) tranny
Every 2-3 years.......Change ALL brake fluid.....do this by "bleeding the system" like you would if there was air in the lines....till the fluid coming out of each caliper is clean.....make sure NOT to run your resevour low doing this or air contamination in the master cylender will result......
Every oil change should include an inspection of the basic things and grease the steering linkage....if you rotat your tires...inspect steering linkages....ball joints...ETC
Marc
Old 12-07-2007, 11:18 PM
Diesel Nick Diesel Nick is offline
I have excessive flatulance!!
Tournaments Won: 1
Send a message via AIM to Diesel Nick
Your brake fluid was looking a little green that right there is funny... It dosen't matter what color your brake fluid is as long as its DOT 4 and when you test brake fluid you test it for how much water is in it... I hope u didn't pay for this "color check" and your tranny fluid not begin as red as it should be? They are just trying to get you to get ur service work done with them... You change your fluids regularly you will be fine... I work at a stealership I know the deal the "color check" in my opinion is there game...
Old 12-07-2007, 11:19 PM
Diesel Nick, nice truck bud (don't mean to steal post-its just bad a$$)
Old 12-07-2007, 11:24 PM
Tournaments Won: 1
Thanx bro
Old 12-07-2007, 11:36 PM
Rob Rob is offline
Free Faller
Send a message via AIM to Rob Send a message via MSN to Rob Send a message via Yahoo to Rob Send a message via Skype™ to Rob
BigRed, i like your avatar. i work at Hill AFB in the C-130 Depot. man those planes are just worn out when we get them for their PDM...
Old 12-07-2007, 11:49 PM
Northwest Stroker
Hey thanks for the response. I suspected the color didn't mean squat for brake fluid. And I thought I could find something from maintain, just didn't look in the right spot I guess.
Old 12-07-2007, 11:53 PM
Rob Rob is offline
Free Faller
yeah they were trying to pull one over on ya!
Old 12-07-2007, 11:56 PM
Northwest Stroker
Hey thanks, I just snatched it from some random AF sight. Hill AFB huh, I was stationed at Travis from 98-2000. And crazy thing is, I grew up on that base, my dad was station there from 83-92. I went reserve in 05 stationed at McChord. 130's are still kick a$$ when it comes to combat drops into an AOR. Not the most comfy rides but I like em.
Old 12-08-2007, 12:01 AM
Northwest Stroker
RWalker, how do you like your pro comp lift, I was thinkin of going 4". I heard that pro comp is just the same as rancho, just with a different sticker.
