  #11 (permalink)
Old 12-10-2007, 03:48 PM
fordnut85 fordnut85 is offline
7.3 tech, supporter
If it is effecting your speedo and cruise it won't be the front wheel sensors, it will be the one in the rear diff. I think they run about $20-$30.
  #12 (permalink)
Old 12-10-2007, 03:57 PM
strokin_early_99 strokin_early_99 is offline
John Wood Nut Swinger
He already replaced the VSS.
  #13 (permalink)
Old 12-10-2007, 04:02 PM
7.3 tech, supporter
Opps, my bad.
Next step would be to put a scan tool on it and see if the PCM is registering a reading from the VSS. That way you could elimnate the VSS circuit all together.
  #14 (permalink)
Old 12-10-2007, 04:39 PM
schwarz_06 schwarz_06 is offline
we plugged in the snap on scanner and it cant communicate with the abs module. so our guess is that the abs module is bad. if anyone else has any ideas feel free to let me know.
  #15 (permalink)
Old 12-10-2007, 07:43 PM
7.3 tech, supporter
Check fuses first, if they are all good then it's a good bet the ABS mosule is out.
  #16 (permalink)
Old 12-11-2007, 02:32 PM
bricklayer99 bricklayer99 is offline
I'm still real green in the powerstroke world but I remember someone stating that there is another VSS on top of the transfercase on 4x4's and on the rear diff??
  #17 (permalink)
Old 12-11-2007, 02:34 PM
Mercury Mercury is offline
Send a message via AIM to Mercury
FYI if the rear ABS module is unplugged, speed still reads on my truck - and it comes from the front ABS sensors....
ken
  #18 (permalink)
Old 12-11-2007, 06:53 PM
haha ok here you go guys. all this nonsense with the abs module. i bet non of you would every consider this. the body shop that had the truck painted some piece of metal really damn good. well they painted it so damn good that the wire that is supposed to ground the module couldnt get any connection with the metal. well if there is no ground then there is no complete circuit and that means no power and no communication to the module. problem solved and on the body shop's dime.
  #19 (permalink)
Old 12-11-2007, 06:57 PM
I did not know you were getting stuff repainted... I I was the body shop and removed the ground of anything I surely would have kept that as a possibility
Glad you found it... so it was the module... - just that it did not have power or power was "intermittent"
Kenny
  #20 (permalink)
Old 12-12-2007, 07:22 AM
well this whole issue came about after a wreck and when they painted it started my lil fiasco. but martha is running just as good as new, plus i took care of my the recall with the cmp so i killed two birds with one stone.
