Old 12-06-2007, 06:50 PM
militaryman3756 militaryman3756 is offline
vibration/shimmy problem
i drive a 2000 7.3 psd and it just started doing this shimmy/vibration thing today, and the check engine light comes on but then it'll go away and be alright again and the light will go out. any ideas???
Old 12-07-2007, 08:36 AM
dieselcrawler dieselcrawler is offline
Thoese that know need more info... when does it do this, what are the conditions, speeds, RPMs, etc.... could be alot of things...
I don't know, but I'll bump this up for ya...
Old 12-08-2007, 12:07 PM
well see, the light wasn't on when i cranked it a min ago. but when the light is on, it runs rough all through the rpm range and especially vibratey in 4th. and when i press the gas pedal it takes it a bit to react. i do have a ts 6 pos chip in it, i'm about to take it out and see what that does to it.
Old 12-08-2007, 12:08 PM
landofconfusion landofconfusion is offline
Send a message via AIM to landofconfusion
no lift or tire size increase?
not to sure other than that, but i'll help you bump also.
Old 12-08-2007, 12:09 PM
bigcountrysg bigcountrysg is offline
duct tape & zip ties
Does the vibration come and go with the light.
Old 12-08-2007, 12:18 PM
Builttuff Builttuff is offline
Im thinking I read on here somewhere that a bad or going bad injector will cause that.
Old 12-08-2007, 06:19 PM
yeah, when the light is on it vibes, when the light is off, it's perfect.
Old 12-08-2007, 06:25 PM
nope, nothing has changed
Old 12-08-2007, 07:19 PM
jonniebahama jonniebahama is offline
Im going through the same deal. But now the light stays on all the time. Did you run it low on fuel anytime. There should be a inframe fuel pump under the driverside, try taping on it, or see if you have air in the system. The Dealership wants 200 bucks to tell me whats wrong. i seen a fuel pum on ebay for 83 dollars.. Just start at the tank and check the the filters and line..
Old 12-08-2007, 09:44 PM
alberta 7.3 alberta 7.3 is offline
<- Insert Dana 60 here!
It would help if you could pull some trouble codes with a PSD-compatible reader. If it is an injector issue (as Builttuff mentioned) it could potentially set a P1316 code (IDM/injector codes present) Since this sounds intermittent, and if a 1316 code is spit out, check undervalve cover harnesses and connectors for loose/damage/burned connections, or rubbing wires on pushrods.
