auxiliary fuel tank - Ford Powerstroke Diesel Forum
Old 08-14-2006, 10:38 AM
auxiliary fuel tank
I am considering adding a fuel tank to my F350, 7.3, 1999 model.
First question: Does this truck have a fuel pump in the fuel tank?
Second quest: If I add a fuel tank & install an electric valve allowing me to pull/pump from and return to each tank separately, should I add that valve before the frame mounted fuel pump, or just how should this be done.
Any/all hlep appreciated.
dinkydau
Boerne, Taxes (Texas)
Old 08-14-2006, 10:49 AM
I don't know nuttin....
dinkydau
I would say you have to add a valve before the pump.
I don't know if it has a pump in the tank though.
Old 08-14-2006, 03:41 PM
Gun Nut
dinkydau
Welcome to Powerstroke.org! Been through Boerne a bunch of times.
Old 08-14-2006, 04:39 PM
dinkydau
No, there is no pump in your tank, just a sending unit for fuel level.
as far as how to mount it, i like gravity feeding it into the primary tank if all your gonna carry is diesel, but you want to have it on a dump vavle so you are always dumping. This allows you to keep a better idea of how much fuel you really have.......problem is this requires a hole in the bed. Then just T into the main filler and put the vavle somewhere on the secondary tanks line......
Old 08-14-2006, 05:27 PM
Boerne was a great place to live until uncontrolled growth took over. Now you can not swing a dead cat without hitting someone.
Old 08-14-2006, 05:36 PM
Send a message via Yahoo to ndurbin
I had twin tanks on an older ford and ran of a pair of switches (wasn't factory and there when we got the truck). First switched between tanks, Second switched b/w sending units so you could see both tank levels.
