Old 12-06-2007, 08:42 AM
ns954 ns954 is offline
Fuel bowl drain valve leak
I just completed my fuel filter change only to discover that my drain valve is leaking.There is a slow drip coming from the end of the drain tube.Ugh!I thought i could get away with not replacing the o-rings,but i was wrong.Any idea what size o-rings and how many i need?I would like to get them locally to cut down on my "down time".Also,since i've already got the new filter in,could i just unbolt the valve and rebuild it without opening up the fuel bowl again?Thanks alot everyone.I guess i've learned my lesson.
Old 12-06-2007, 01:29 PM
2whlfreak 2whlfreak is offline
You want viton orings 1/2 x 1/4 x 1/8 if you have a Grainger around their # is 1BYU7 $5.67 for 25
Old 12-06-2007, 02:18 PM
I found them for $.50 a piece.Replaced them a few minutes ago and no more leaks!Thanks everyone.Powerstroke.org has been a very helpful website!I searched the previous posts for this subject and found all the info i needed.
For anyone living in the Winston-Salem,NC area a place called Carolina Rubber and Specialties has the viton #202 o-rings in stock.They are located at 4301 Idlewild Industrial Drive in Winston-Salem.
