intake heater for starting? - Ford Powerstroke Diesel Forum
post #1 of 5 Old 02-04-2013, 11:48 PM Thread Starter
Rodslinger's B1TCH
i have a '03 7.3 with some bad glow plugs. it's too freaking cold outside right now to change them out. it starts after torturing the starter for 30 seconds and then runs like a bag of **** for a few minutes. it starts fine if i plug it in but i keep forgetting to plug it in the night before or unplug it before driving away.
has anyone tried jumping a wire from the control side of the glow plug relay to the control side of the intake heater relay? does anyone see a problem with this? is this even worth doing due to the possible lack of heat that heater actually puts out?
steve604 is offline
post #2 of 5 Old 02-05-2013, 04:33 AM
AIH has nothing to do with starting and even if you jumper it out to turn it on it would have minimal effect - one heating element quite a way form the cylinders vs eight right in them
hydroman is offline
post #3 of 5 Old 02-05-2013, 10:38 AM
I disagree with what he said. Last winter I had glow plug relay problems and one time I did jumper the wire for the grid heater while someone cranked it for me and it fired right up. I can't say for sure in extreme temps that it would be the same but it worked great that time for me.
The mid 90's cummins engines only have grid heaters and they start up in cold temps too. I think it would be worth a test to see how it works out.
Matthews is offline
post #4 of 5 Old 02-05-2013, 07:26 PM
dieselcrawler's Avatar
Quoted: 23 Post(s)
Re: intake heater for starting?
Might work in a pinch but I would put my efforts and money into fixxing the glow plugs properly. And then delete the AIH. I put a plug in the hole with a tapped fitting for my boost gauge on my yellow dually.
Sent from my SCH-I200 using AutoGuide.Com Free App
Greg
'99 E350 DRW Stahl 11' util box van, 7.3 PSD, stock. 138k SOLD
'00 F350 extcab, 9' utility bed, dually 228k
E'99 F250 extcab, S/Bed 211k. Sidelined due to motor issues.
'00 Excursion Limited, 7.3PSD 294k
'84 Chevy K-30, 6.2L TD, woods/trail beater. 141k
Semper Paratus
dieselcrawler is offline
post #5 of 5 Old 02-06-2013, 03:20 AM
Plug it in plug it in.
Sent from AutoGuide.com App
2001 F350 SRW CC 4WD LB
ZF6 w/ Southbend, 220k, DIY Intake, WW,NonEBPV Pedestal, CCV Mod, Gauges (Boost, Pyro), 2in Leveling Kit, 4" Straight MBRP, AIH Delete, 2-12" Kicker Comp's, Pioneer Amps
2001 F350 DRW EC 2WD (Rolled Over)
2000 F550 CC 2WD
Automatic, Jasper 4R100 w/Derale Pan & 6.0 Cooler, DIY Intake, AIH Delete, 4" MBRP,
Schnot is offline
