Old 08-13-2006, 08:49 PM
SuperDuty1 SuperDuty1 is offline
Posi-Trac??????????
I would like to upgrade my differential to a limit-slip. I have read thru some of the different ones. I don't want an Air locker or E-locker. I want somthing that will work on its own. I was curious about the Power Traxx. The differential will have to have good road manners, I don't want it trying to bind up when making sharp turns. Does anyone have any suggestion?
Old 08-14-2006, 12:25 PM
Log Dog Log Dog is offline
IMO the Detroit Tru-Trac is the best limited slip on the market. Most LS use clutches to enage the axles, the tru trac uses gears. I know of nobone who has broken one.
Old 08-15-2006, 05:31 AM
Does anyone else have any experience with the detroit tru locker or any other brand?
Old 08-15-2006, 06:03 AM
kyrel69 kyrel69 is offline
Detroit Tru-Trac
my buddy put one in his work truck when the stock carrier broke. He does basment work. They haul around a lot of stuff in the bed of the truck and pull heavy trailer.(bob cat,mini-X's and such) He loved the tru-trac in the rear axle. He said you could not tell it was there untill you got on the gas hard and it would light up both of tires everytime.
I had one in the front of my off-road jeep that I got used and I use it for about 3 year. The case broke b/c it was ment for a C-clip axle and did not have as many gears in it as it would for something that is not a C-clip alxe(like the 10 bolt I am runing) I know if I was to buy something for my truck I would buy a tru-trac. Also you do not need any spec. stuff to put in for clutches since there are none.
Old 08-16-2006, 05:08 AM
I appreciate your info. I did some research on the tru trac. It might just be me, but I really don't see this design working very well for constant daily on & offroad.
Old 08-16-2006, 05:13 AM
Why do you think that???
Old 08-16-2006, 04:36 PM
As opposed to a unit that runs on clutches?. Concider that an automatic transmission runs on clutches, a standard does not. A standard uses a clutch to engage, and what part do you replace most on a standard trans.... Its the same theory. The clutches used in virtually every other limited slip differerential wear out. Plus most require a friction modifier to work properly. The Tru-Trac does not.
Old 08-18-2006, 04:16 AM
Where is a good place to purchase one and do they make one for the front diff.
Old 08-18-2006, 03:25 PM
Are you doing the install yourself? If so I'd go to www.fourwheelparts.com. If you are having the work done for you, hit a local 4x4 shop with a good rep.
Other places to check:
www.4wd.com
www.reiderracing.com
Old 08-18-2006, 09:56 PM
lilredpowerstroke lilredpowerstroke is offline
They sure do thats what I have in the front of mine and it gets abused ummm I mean used hard. So far it seems to be up to the challenge. Im really happy with mine.
