Old 12-04-2007, 10:59 PM
blk99 blk99 is offline
need serious help
I am finally getting around to installing the turbo back into the truck and I cant get the bolt tightened on the driver side uppipe. The one lower/back bolt on the ycollector end of the uppipe. I just can not get anything in there to turn it! I have tried knuckles, a crows foot, my bare hand, every thing I can think of but i cant get too it. I also took out the transmission bolt that was in the way and that didnt help.
I havent even tried the passenger side yet cause I have been working on this side for 5 or 6 hours!!!!
does anybody have any tips, tricks, or ideas?
I need as quick of help as I can get.
Thanks a TON guys!
~Jim
Old 12-04-2007, 11:06 PM
strokin_early_99 strokin_early_99 is offline
John Wood Nut Swinger
ON the drivers side bottom bolt I went up from the bottom with an 18" extension then used a universal adaptor on the end then used a 2" extension and then the socket.
The top one I used a ratchet end wrench from the top of the engine. I had a worse time with the top one than the bottom one.
If you drop the down pipe the passenger side is real easy.
The other thing I did was pretighten everything on the bench and then install them so I did not have to mash the donuts as much with all the extensions stuck together.
