Old 12-04-2007, 04:07 PM
Black Pwrstroke Black Pwrstroke is offline
Has anyone put there truck on a dyno
I dnt know much about the dyno machines and dnt know if i still have to go with my 3rd setting or can i put it on my 4,120 or 5,140 setting on a dyno???
Old 12-04-2007, 04:11 PM
rankroddin250 rankroddin250 is offline
I cant see any reason why you wouldnt be able to unless you cant keep the egt's down long enough to do a 140 hp run.
Old 12-04-2007, 04:12 PM
will my stock tranny fall out.lol
Old 12-04-2007, 04:17 PM
SMKSTAX SMKSTAX is offline
KCR DIRECTOR
I ran my truck recently and went stock, 75hp, and 140hp settings. Everything was fine. You can change settings to whatever you want.
Old 12-04-2007, 04:19 PM
so the dyno doesnt put as much stress on your tranny like cement does.
I would hope not. if so id rather drop it out on the dyno than drag racing a honda. that would be more embarasing.
Old 12-04-2007, 04:20 PM
it should only stress your tranny about as much as a heavy trailer as long as your dyno guy knows what hes doing.
Old 12-04-2007, 04:21 PM
just worried bout messing up my tranny. dnt have the money to upgrade yet.
Old 12-04-2007, 07:15 PM
just so i know if i put my truck on a dyno machine i could run it on my hottes setting wich would be 140hp on my dp with my stock tranny and mostly stock engine i should be worried at all.
Old 12-04-2007, 07:21 PM
KCR DIRECTOR
I see you have gauges and i assume one of them is a pyrometer so just keep tabs of your EGT's. If it get's too hot just cut it off. But i really don't think you'll have any problems. A pull only lasts like 5 seconds at WOT.
