2002 powerstroke smoking when cold
I have a problem and I'm running out of ideas. Last year I had har starting issues due to worn injectors. I pulled them all and had Rosewood rebuild them into stage 1 single shots. While I was in there I replaced all 8 glow plugs and the valve cover gaskets. Before I did the rebuild I had no white smoke.
Now when I crank the truck it rolls white smoke and has zero throttle response. The exhaust will burn you eyes and smells like straight fuel. I can run it down the street and it quits pretty quickly. In the summer months this doesnt happen. This leads me to belive that its a glow pulg problem, but they test out. I'm stumped. I cant afford to put it in the shop and the neighbors are starting to complain. |
Does it just start smoking like this at a certain temperature or does it smoke more/less depending on how cold it is? Who's tuning are you running? Sounds a little loud, but it could be from the single shots. May be an injector sticking.
I'd start simple, check the glow plugs and relay. Troubleshooting GPR & GP's |
Its running a dp tune and it only does this when its under 50 degrees. The plugs and relay check out.
sounds like maybe injector issue. sticking possibly. what was the temp in the video? It lit pretty quick to be a glow plug issue.
I think TJ's on the right path with the Injector's.
You might have a leaky or stuck injector and recommend you have some do a check on yours. If you know someone in your area that has AutoEnguity (AE) that they can swing by and do some diagnosis on it, ask them. Mine will do that when it's really cold - on a cold start (ie - not plugging in the heater) when it's 20degrees or colder. It will give a light bit of white smoke on the cold start - but nothing like that. Does it go away after it warms up? Might even want you have your chip/tunes re-checked... |
Mine was doing that too. Replaced all the injector o-rings last month.....problem solved. I know you just had the injectors rebuilt but its possible the o-rings were damaged upon install....its pretty easy to nick them or put a crack in them, especially the pink rings. Just a thought anyway....
Yep it quits smoking when it warms up. Matter of fact I can crank it cold and take off down the street and go maybe a 100 yards and it quits. Jody at DP tuner said he had a timing saftey on my PCM, and would remove it, but I havent made my way to him yet.
Do you use any fuel additives? Could try using one or changing what one you're using. My truck smoked more on one additive over the other 2 I've used. Unlikely this will solve the problem, but it might help. |
I dont have any tunes. Its just a PMC reflash at a stock setting just to run the single shots. I was thinking it may be injector timing. Shooting to late. Not sure. Havent been running any fuel additives.
Also not sure if it matters, but even in the summer time the exhaust wreaks of diesel. It dosent smoke, but will cook your eyes if you get near the back |
