Truck won't unlock, pretty frustrated... - Ford Powerstroke Diesel Forum
post #1 of 11 Old 02-01-2013, 11:55 PM Thread Starter
Quoted: 4 Post(s)
Went to the movies tonight, before the movie everything was working fine. When it was done I went to unlock the truck with the key fob and nothing. The lock button still worked, but it wasn't responding to the unlock button.
I figured it was the key fob running low on batteries or something, so I unlocked the truck manually. Once I got in I tried using the unlock button on the door, absolutely nothing. No clicking sound or anything, but the lock button on the door still worked fine. Tried it again once I got back to base and still nothing.
I assume it's something electrical, but other than that I'm completely stumped. A little help?
It's an '01 F250 CCSB.
Thanks you,
Zack
Bakes168 is offline
post #2 of 11 Old 02-02-2013, 03:41 AM
Wannabitawerm's Avatar
Could be the switch in the door. Pretty easily replaced. You can order the switches seperate.
Sent from AutoGuide.com App
Wannabitawerm is offline
post #3 of 11 Old 02-02-2013, 06:47 AM
Zaairman's Avatar
Quoted: 12 Post(s)
Sounds like your door lock actuators are getting weak and don't have enough power to unlock the doors. Can you hear them trying to unlock when you hit the button?
Zach
2000/2006ish Ford F-250 Larryette 7.3 Powerstroke 4x4
5" Sewer Pipe Exhaust
, DIY 6637 Intake, Wicked Wheel'd, De-foiled, Missing EBPV, Edge Juice with Attitude, Few leaves added here and there, 35" BFGs, 16x10 Eagle Alloys, Alpine W200
SLAPS Member #153
Zaairman is offline
post #4 of 11 Old 02-02-2013, 07:02 AM
ZMANN's Avatar
Quoted: 1342 Post(s)
you don't happen to have 2 fobs do you ?
We Miss you Ronnie
ZMANN is online now
post #5 of 11 Old 06-23-2013, 11:59 PM Thread Starter
Quoted: 4 Post(s)
Sorry I never got back to any of you, the problem went away the next day and I forgot about the thread.
However, it has happened again. I got in the truck and drove it, got to where I was going and when I got out tried to lock the truck...but nothing happened. I tried both buttons on the key fob and got nothing. I opened the door and tried both the lock and unlock buttons on the door and got nothing. I can hear a clicking coming from under the steering wheel when I push any of the buttons, I'm assuming it's a relay but I'm not sure where to go from here.
Your help is greatly appreciated.
Semper Fi, Zack
Bakes168 is offline
post #6 of 11 Old 06-24-2013, 05:18 AM
schlutzer's Avatar
Quoted: 18 Post(s)
Like was already said, the door lock actuators on these trucks are terrible for going out. I would bet thats your problem....
Replace with aftermarket or do the tin foil trick and youll be sailing again.
schlutzer is offline
post #7 of 11 Old 06-24-2013, 06:15 AM Thread Starter
Quoted: 4 Post(s)
Thanks Schlutzer, but I've already done the tin trick on all four doors, and I doubt they would all go out again at the same time.
When any button is pushed I cant hear anything from the doors, just that clicking under the steering wheel.
Bakes168 is offline
post #8 of 11 Old 06-24-2013, 09:57 AM Thread Starter
Quoted: 4 Post(s)
Now that I think about it, the night that the locks quit working I remember driving with the windows down and smelling something burning. It smelled like burning plastic, but I assumed it was something outside that I had driven past.
Could there have been some sort of short in the wiring under the dash?
Bakes168 is offline
post #9 of 11 Old 06-24-2013, 11:44 AM
Quoted: 17 Post(s)
That's possible. Also possible that one of your actuators had a short or took more amps to actuate & overloaded the relay,wire,wire connectors or fuse.
2000 Ford Excursion Limited 4x4 Diesel
2007 Jeep Wrangler unlimited on 1 tons & with 41.5" Pitbull Rockers
TBJK is offline
post #10 of 11 Old 06-25-2013, 09:42 AM Thread Starter
Quoted: 4 Post(s)
Is there a thread somewhere showing how to take the dash apart and get to all the wiring, along with a wiring diagram?
Bakes168 is offline
