random acts of dieing - Ford Powerstroke Diesel Forum
Old 12-01-2007, 07:24 PM
i have a 2002 f350 with a 7.3 litre diesel engine.truck runs fine when its cold,but dies when it gets up to operating temperature.i live in alberta and temperature is -20c. will start and run after it has stalled but will die quickley. hooked up diagnostic reader but nothing showed up, engine light not on.i recently put a afe stage 2 cold air intake on, would the IAT sensor have anything to do with it. if anyone has any tips or the same problem please message me with a solution.thanks
Old 12-01-2007, 07:52 PM
Powerstroke Techie
I would put money on it is the CPS (cam position sensor) they now cost less than $25 and are very easy to change. I keep a spare in the glove box. When mine went out it acted just as you describe. One check is to see if the tach goes to zero or acts funny as it dies, the sensor also runs the tach. A 10mm wrench and less than 5 minutes and you should have her fixed.
Old 12-02-2007, 08:20 AM
Welcome to guzzle's CPS R&R Web Page
Old 12-02-2007, 08:22 AM
KVFD
cps all the way i am guessing it hickups and the check engine light is on! i would replace it anyway! all my buddies with psd have replaced the cps and i did too!
Old 12-02-2007, 09:13 AM
Thanks for getting back to me fellers. Im going to buy one possibley two tomorrow so i have a extra. So when the cps goes, will it somtimes not let the motor fire at all, or until it cools down. is that one of the symtoms, and the engine light has only come on twice. while the truck has been died about 20 times.
Old 12-02-2007, 09:16 AM
If the CPS is totally gone the motor will not fire at all, and your tach will not move either when cranking.
Old 12-02-2007, 09:17 AM
KVFD
another thing could be is your diesel gelling up in the cold weather? maybe run some diesel 911 in the tank could help
Old 12-02-2007, 10:23 AM
I only run good clean diesel, an i have been putting conditioner in it. I havent noticed the tach doing anything funky, but i did notice that the oil psi, fuel level, engine temp ,and tranny temp gauges drop down about a 1/4 inch bellow were they should be, thats only when the truck dies, if that makes any sense.
Old 12-02-2007, 10:25 AM
whats the temps where your at
Old 12-02-2007, 03:54 PM
one sad ford
Im in Edmonton Alberta , the overhead digital temp in my truck says -22 c. Im positive that it isnt my fuel gelling up. I drove the truck around for an hour or so today, an it ran fine, shut it off for 15 mins and went back outside a few minutes ago an it would'nt start.
